Mark Holtz
- Feb 3, 2015
So, I'm trying to utilize the Audiobookshelf which was an official release earlier this week on TrueNAS scale. The app installed fine, and I have it configured with Network Configuration → Host Network enabled so that I can use port forwarding to access my server externally. I'm only importing one of my libraries, but about 20 books load before the instance crashes. The "Related Kubernetes Events" shows the following:
And when I look at the application logs, I see the following:
Is this a container error or a program error?
[B]2024-03-30 09:06:08[/B]Readiness probe failed: Get "http://192.168.1.2:30067/healthcheck": dial tcp 192.168.1.2:30067: connect: connection refused
[B]2024-03-30 09:06:08[/B]Liveness probe failed: Get "http://192.168.1.2:30067/healthcheck": dial tcp 192.168.1.2:30067: connect: connection refused
[B]2024-03-30 09:05:16[/B]Back-off restarting failed container audiobookshelf in pod audiobookshelf-995997dd8-tfhq6_ix-audiobookshelf(1d7eccc4-89f8-414e-9644-070bafa14f56)
[B]2024-03-30 09:05:11[/B]Container image "ghcr.io/advplyr/audiobookshelf:2.8.1" already present on machine
[B]2024-03-30 09:01:34[/B]Created container audiobookshelf
[B]2024-03-30 09:01:34[/B]Started container audiobookshelf
[B]2024-03-30 09:01:33[/B]Successfully pulled image "ghcr.io/advplyr/audiobookshelf:2.8.1" in 15.383561681s (15.383573355s including waiting)
[B]2024-03-30 09:01:17[/B]Pulling image "ghcr.io/advplyr/audiobookshelf:2.8.1"
[B]2024-03-30 09:01:11[/B]Created container audiobookshelf-install-01-permissions
[B]2024-03-30 09:01:11[/B]Started container audiobookshelf-install-01-permissions
[B]2024-03-30 09:01:09[/B]Container image "bash:4.4.23" already present on machine
[B]2024-03-30 09:01:08[/B]Scaled up replica set audiobookshelf-995997dd8 to 1
[B]2024-03-30 09:01:08[/B]Created pod: audiobookshelf-995997dd8-tfhq6
[B]2024-03-30 09:01:08[/B]Successfully assigned ix-audiobookshelf/audiobookshelf-995997dd8-tfhq6 to ix-truenas
2024-03-30 09:10:50.773
DEBUG
[ApiCacheManager] Cache hit: {"user":"root","url":"/libraries/aa32047f-fc37-43cf-a312-c12ace461c7b?include=filterdata"}
2024-03-30 09:10:50.837
DEBUG
[ApiCacheManager] count: 2 size: 57415
2024-03-30 09:10:50.902
FATAL
[Server] Unhandled rejection: SequelizeDatabaseError: SQLITE_IOERR: disk I/O error, promise: Promise { <rejected> Error at Database.<anonymous> (/node_modules/sequelize/lib/dialects/sqlite/query.js:185:27) at /node_modules/sequelize/lib/dialects/sqlite/query.js:183:50 at new Promise (<anonymous>) at Query.run (/node_modules/sequelize/lib/dialects/sqlite/query.js:183:12) at /node_modules/sequelize/lib/sequelize.js:315:28 at async SQLiteQueryInterface.select (/node_modules/sequelize/lib/dialects/abstract/query-interface.js:407:12) at async book.findAll (/node_modules/sequelize/lib/model.js:1140:21) at async Promise.all (index 1) at async book.findAndCountAll (/node_modules/sequelize/lib/model.js:1322:27) at async Object.getFilteredLibraryItems (/server/utils/queries/libraryItemsBookFilters.js:560:36) { name: 'SequelizeDatabaseError', parent: [Error: SQLITE_IOERR: disk I/O error] { errno: 10, code: 'SQLITE_IOERR', sql: "SELECT `book`.`id`, `book`.`title`, `book`.`titleIgnorePrefix`, `book`.`subtitle`, `book`.`publishedYear`, `book`.`publishedDate`, `book`.`publisher`, `book`.`description`, `book`.`isbn`, `book`.`asin`, `book`.`language`, `book`.`explicit`, `book`.`abridged`, `book`.`coverPath`, `book`.`duration`, `book`.`narrators`, `book`.`audioFiles`, `book`.`ebookFile`, `book`.`chapters`, `book`.`tags`, `book`.`genres`, `book`.`createdAt`, `book`.`updatedAt`, `libraryItem`.`id` AS `libraryItem.id`, `libraryItem`.`ino` AS `libraryItem.ino`, `libraryItem`.`path` AS `libraryItem.path`, `libraryItem`.`relPath` AS `libraryItem.relPath`, `libraryItem`.`mediaId` AS `libraryItem.mediaId`, `libraryItem`.`mediaType` AS `libraryItem.mediaType`, `libraryItem`.`isFile` AS `libraryItem.isFile`, `libraryItem`.`isMissing` AS `libraryItem.isMissing`, `libraryItem`.`isInvalid` AS `libraryItem.isInvalid`, `libraryItem`.`mtime` AS `libraryItem.mtime`, `libraryItem`.`ctime` AS `libraryItem.ctime`, `libraryItem`.`birthtime` AS `libraryItem.birthtime`, `libraryItem`.`size` AS `libraryItem.size`, `libraryItem`.`lastScan` AS `libraryItem.lastScan`, `libraryItem`.`lastScanVersion` AS `libraryItem.lastScanVersion`, `libraryItem`.`libraryFiles` AS `libraryItem.libraryFiles`, `libraryItem`.`extraData` AS `libraryItem.extraData`, `libraryItem`.`createdAt` AS `libraryItem.createdAt`, `libraryItem`.`updatedAt` AS `libraryItem.updatedAt`, `libraryItem`.`libraryId` AS `libraryItem.libraryId`, `libraryItem`.`libraryFolderId` AS `libraryItem.libraryFolderId`, `libraryItem->feeds`.`id` AS `libraryItem.feeds.id`, `libraryItem->feeds`.`slug` AS `libraryItem.feeds.slug`, `libraryItem->feeds`.`entityType` AS `libraryItem.feeds.entityType`, `libraryItem->feeds`.`entityId` AS `libraryItem.feeds.entityId`, `libraryItem->feeds`.`entityUpdatedAt` AS `libraryItem.feeds.entityUpdatedAt`, `libraryItem->feeds`.`serverAddress` AS `libraryItem.feeds.serverAddress`, `libraryItem->feeds`.`feedURL` AS `libraryItem.feeds.feedURL`, `libraryItem->feeds`.`imageURL` AS `libraryItem.feeds.imageURL`, `libraryItem->feeds`.`siteURL` AS `libraryItem.feeds.siteURL`, `libraryItem->feeds`.`title` AS `libraryItem.feeds.title`, `libraryItem->feeds`.`description` AS `libraryItem.feeds.description`, `libraryItem->feeds`.`author` AS `libraryItem.feeds.author`, `libraryItem->feeds`.`podcastType` AS `libraryItem.feeds.podcastType`, `libraryItem->feeds`.`language` AS `libraryItem.feeds.language`, `libraryItem->feeds`.`ownerName` AS `libraryItem.feeds.ownerName`, `libraryItem->feeds`.`ownerEmail` AS `libraryItem.feeds.ownerEmail`, `libraryItem->feeds`.`explicit` AS `libraryItem.feeds.explicit`, `libraryItem->feeds`.`preventIndexing` AS `libraryItem.feeds.preventIndexing`, `libraryItem->feeds`.`coverPath` AS `libraryItem.feeds.coverPath`, `libraryItem->feeds`.`createdAt` AS `libraryItem.feeds.createdAt`, `libraryItem->feeds`.`updatedAt` AS `libraryItem.feeds.updatedAt`, `libraryItem->feeds`.`userId` AS `libraryItem.feeds.userId` FROM `books` AS `book` INNER JOIN `libraryItems` AS `libraryItem` ON `book`.`id` = `libraryItem`.`mediaId` AND (`libraryItem`.`libraryId` = 'aa32047f-fc37-43cf-a312-c12ace461c7b' AND `libraryItem`.`mediaType` = 'book') LEFT OUTER JOIN `feeds` AS `libraryItem->feeds` ON `libraryItem`.`id` = `libraryItem->feeds`.`entityId` AND `libraryItem->feeds`.`entityType` = 'libraryItem' ORDER BY titleIgnorePrefix COLLATE NOCASE ASC LIMIT 0, 100;" }, original: [Error: SQLITE_IOERR: disk I/O error] { errno: 10, code: 'SQLITE_IOERR', sql: "SELECT `book`.`id`, `book`.`title`, `book`.`titleIgnorePrefix`, `book`.`subtitle`, `book`.`publishedYear`, `book`.`publishedDate`, `book`.`publisher`, `book`.`description`, `book`.`isbn`, `book`.`asin`, `book`.`language`, `book`.`explicit`, `book`.`abridged`, `book`.`coverPath`, `book`.`duration`, `book`.`narrators`, `book`.`audioFiles`, `book`.`ebookFile`, `book`.`chapters`, `book`.`tags`, `book`.`genres`, `book`.`createdAt`, `book`.`updatedAt`, `libraryItem`.`id` AS `libraryItem.id`, `libraryItem`.`ino` AS `libraryItem.ino`, `libraryItem`.`path` AS `libraryItem.path`, `libraryItem`.`relPath` AS `libraryItem.relPath`, `libraryItem`.`mediaId` AS `libraryItem.mediaId`, `libraryItem`.`mediaType` AS `libraryItem.mediaType`, `libraryItem`.`isFile` AS `libraryItem.isFile`, `libraryItem`.`isMissing` AS `libraryItem.isMissing`, `libraryItem`.`isInvalid` AS `libraryItem.isInvalid`, `libraryItem`.`mtime` AS `libraryItem.mtime`, `libraryItem`.`ctime` AS `libraryItem.ctime`, `libraryItem`.`birthtime` AS `libraryItem.birthtime`, `libraryItem`.`size` AS `libraryItem.size`, `libraryItem`.`lastScan` AS `libraryItem.lastScan`, `libraryItem`.`lastScanVersion` AS `libraryItem.lastScanVersion`, `libraryItem`.`libraryFiles` AS `libraryItem.libraryFiles`, `libraryItem`.`extraData` AS `libraryItem.extraData`, `libraryItem`.`createdAt` AS `libraryItem.createdAt`, `libraryItem`.`updatedAt` AS `libraryItem.updatedAt`, `libraryItem`.`libraryId` AS `libraryItem.libraryId`, `libraryItem`.`libraryFolderId` AS `libraryItem.libraryFolderId`, `libraryItem->feeds`.`id` AS `libraryItem.feeds.id`, `libraryItem->feeds`.`slug` AS `libraryItem.feeds.slug`, `libraryItem->feeds`.`entityType` AS `libraryItem.feeds.entityType`, `libraryItem->feeds`.`entityId` AS `libraryItem.feeds.entityId`, `libraryItem->feeds`.`entityUpdatedAt` AS `libraryItem.feeds.entityUpdatedAt`, `libraryItem->feeds`.`serverAddress` AS `libraryItem.feeds.serverAddress`, `libraryItem->feeds`.`feedURL` AS `libraryItem.feeds.feedURL`, `libraryItem->feeds`.`imageURL` AS `libraryItem.feeds.imageURL`, `libraryItem->feeds`.`siteURL` AS `libraryItem.feeds.siteURL`, `libraryItem->feeds`.`title` AS `libraryItem.feeds.title`, `libraryItem->feeds`.`description` AS `libraryItem.feeds.description`, `libraryItem->feeds`.`author` AS `libraryItem.feeds.author`, `libraryItem->feeds`.`podcastType` AS `libraryItem.feeds.podcastType`, `libraryItem->feeds`.`language` AS `libraryItem.feeds.language`, `libraryItem->feeds`.`ownerName` AS `libraryItem.feeds.ownerName`, `libraryItem->feeds`.`ownerEmail` AS `libraryItem.feeds.ownerEmail`, `libraryItem->feeds`.`explicit` AS `libraryItem.feeds.explicit`, `libraryItem->feeds`.`preventIndexing` AS `libraryItem.feeds.preventIndexing`, `libraryItem->feeds`.`coverPath` AS `libraryItem.feeds.coverPath`, `libraryItem->feeds`.`createdAt` AS `libraryItem.feeds.createdAt`, `libraryItem->feeds`.`updatedAt` AS `libraryItem.feeds.updatedAt`, `libraryItem->feeds`.`userId` AS `libraryItem.feeds.userId` FROM `books` AS `book` INNER JOIN `libraryItems` AS `libraryItem` ON `book`.`id` = `libraryItem`.`mediaId` AND (`libraryItem`.`libraryId` = 'aa32047f-fc37-43cf-a312-c12ace461c7b' AND `libraryItem`.`mediaType` = 'book') LEFT OUTER JOIN `feeds` AS `libraryItem->feeds` ON `libraryItem`.`id` = `libraryItem->feeds`.`entityId` AND `libraryItem->feeds`.`entityType` = 'libraryItem' ORDER BY titleIgnorePrefix COLLATE NOCASE ASC LIMIT 0, 100;" }, sql: "SELECT `book`.`id`, `book`.`title`, `book`.`titleIgnorePrefix`, `book`.`subtitle`, `book`.`publishedYear`, `book`.`publishedDate`, `book`.`publisher`, `book`.`description`, `book`.`isbn`, `book`.`asin`, `book`.`language`, `book`.`explicit`, `book`.`abridged`, `book`.`coverPath`, `book`.`duration`, `book`.`narrators`, `book`.`audioFiles`, `book`.`ebookFile`, `book`.`chapters`, `book`.`tags`, `book`.`genres`, `book`.`createdAt`, `book`.`updatedAt`, `libraryItem`.`id` AS `libraryItem.id`, `libraryItem`.`ino` AS `libraryItem.ino`, `libraryItem`.`path` AS `libraryItem.path`, `libraryItem`.`relPath` AS `libraryItem.relPath`, `libraryItem`.`mediaId` AS `libraryItem.mediaId`, `libraryItem`.`mediaType` AS `libraryItem.mediaType`, `libraryItem`.`isFile` AS `libraryItem.isFile`, `libraryItem`.`isMissing` AS `libraryItem.isMissing`, `libraryItem`.`isInvalid` AS `libraryItem.isInvalid`, `libraryItem`.`mtime` AS `libraryItem.mtime`, `libraryItem`.`ctime` AS `libraryItem.ctime`, `libraryItem`.`birthtime` AS `libraryItem.birthtime`, `libraryItem`.`size` AS `libraryItem.size`, `libraryItem`.`lastScan` AS `libraryItem.lastScan`, `libraryItem`.`lastScanVersion` AS `libraryItem.lastScanVersion`, `libraryItem`.`libraryFiles` AS `libraryItem.libraryFiles`, `libraryItem`.`extraData` AS `libraryItem.extraData`, `libraryItem`.`createdAt` AS `libraryItem.createdAt`, `libraryItem`.`updatedAt` AS `libraryItem.updatedAt`, `libraryItem`.`libraryId` AS `libraryItem.libraryId`, `libraryItem`.`libraryFolderId` AS `libraryItem.libraryFolderId`, `libraryItem->feeds`.`id` AS `libraryItem.feeds.id`, `libraryItem->feeds`.`slug` AS `libraryItem.feeds.slug`, `libraryItem->feeds`.`entityType` AS `libraryItem.feeds.entityType`, `libraryItem->feeds`.`entityId` AS `libraryItem.feeds.entityId`, `libraryItem->feeds`.`entityUpdatedAt` AS `libraryItem.feeds.entityUpdatedAt`, `libraryItem->feeds`.`serverAddress` AS `libraryItem.feeds.serverAddress`, `libraryItem->feeds`.`feedURL` AS `libraryItem.feeds.feedURL`, `libraryItem->feeds`.`imageURL` AS `libraryItem.feeds.imageURL`, `libraryItem->feeds`.`siteURL` AS `libraryItem.feeds.siteURL`, `libraryItem->feeds`.`title` AS `libraryItem.feeds.title`, `libraryItem->feeds`.`description` AS `libraryItem.feeds.description`, `libraryItem->feeds`.`author` AS `libraryItem.feeds.author`, `libraryItem->feeds`.`podcastType` AS `libraryItem.feeds.podcastType`, `libraryItem->feeds`.`language` AS `libraryItem.feeds.language`, `libraryItem->feeds`.`ownerName` AS `libraryItem.feeds.ownerName`, `libraryItem->feeds`.`ownerEmail` AS `libraryItem.feeds.ownerEmail`, `libraryItem->feeds`.`explicit` AS `libraryItem.feeds.explicit`, `libraryItem->feeds`.`preventIndexing` AS `libraryItem.feeds.preventIndexing`, `libraryItem->feeds`.`coverPath` AS `libraryItem.feeds.coverPath`, `libraryItem->feeds`.`createdAt` AS `libraryItem.feeds.createdAt`, `libraryItem->feeds`.`updatedAt` AS `libraryItem.feeds.updatedAt`, `libraryItem->feeds`.`userId` AS `libraryItem.feeds.userId` FROM `books` AS `book` INNER JOIN `libraryItems` AS `libraryItem` ON `book`.`id` = `libraryItem`.`mediaId` AND (`libraryItem`.`libraryId` = 'aa32047f-fc37-43cf-a312-c12ace461c7b' AND `libraryItem`.`mediaType` = 'book') LEFT OUTER JOIN `feeds` AS `libraryItem->feeds` ON `libraryItem`.`id` = `libraryItem->feeds`.`entityId` AND `libraryItem->feeds`.`entityType` = 'libraryItem' ORDER BY titleIgnorePrefix COLLATE NOCASE ASC LIMIT 0, 100;", parameters: {} } }
