jenksdrummer
- Jun 7, 2011
Tried several times to remove an L2ARC as I didn't want the M.2 SSD taking burn for copying off data so I can wipe/reload the box as I'm concerned that 12-RELEASE is actually less stable than 12RC1...
Box locks up. Have to reboot via IPMI as the thread won't die. Boot ups then have been hit or miss, it'd get so far then reset the box; tried 3 different times; same lock up. After a forced reboot, system would boot up only so far (to different points; once was at the FreeNAS/TrueNAS boot menu just after selection, the other two were after that,) then reset, then boot up normally. I've removed L2ARC many times in the past w/o issue; so not my first rodeo; not sure what the deal is. Ran a scrub, no issues. L2ARC is still there. Left it alone just so I can make sure I have a copy of my data elsewhere at this point as I am losing faith that this is a good release...
