rszasz
- Nov 1, 2017
I wanted to try a couple of plugins, and selected the VNET option that I hoped could I bind to an unused network interface and then I could connect any plugins or jails to it.
Unfortunately the moment I created the jail I lost connectivity to the machine and couldn't reconnect. Creating the VNET created a bridge that automatically included the primary network interface AND the secondary interface, connected to the same network segment, and screwed everything up.
Is there a way to configure the bridge interface so it only connects the interfaces I want it to? Or, if I want jails separated from the primary interface, am I stuck assigning them to network interfaces until I run out? Is it even worse and I can't do this at all because jail network interfaces aren't fully separated from the main stack like a VM would be? (and connecting multiple interfaces with IP addresses to the same network segment breaks stuff)
