dnel
- May 27, 2011
I have a HP microserver and 2x500GB disks and 3x250GB disks. I'd like to configure these to create a zpool that provides some resiliancy but maximum available disk space.
I'd also like to be able to upgrade the disks in the future to expand the available space.
After doing some reading I think I should create a RAIDZ array using the 500GB disks but I think I need an extra 500GB disk?
I could buy another 500GB disk but I'd rather put that money towards some large disks to upgrade the array in the near future, until then could I create a 500GB stripe from two of the 250GB disks and use this is the 3rd disk in the array, is this likely to cause any problems?
Also, I only have 1GB memory in the machine, is this configuration going to be possible with this little memory or will performance just be slow and how slow?
The server is only for home use so gets very little demand most of the time.
Any advice would be appreciated.
Thanks,
dnel
Thanks,
dnel
