ornias
- Mar 6, 2020
ornias submitted a new resource:
ArgoCD on SCALE - SCALE meets gitops
Read more about this resource...
As part of my work on K8S-at-Home and TrueCharts, I wanted to investigate the possibility to deploy a normal gitops-based kubernetes system on top of SCALE. In such a way that it wouldn't interfere or break the TrueNAS SCALE Apps system.
This is very well possible, although you do need to ensure you:
- Create a seperate storageClass
- Make sure the API is available on another computer (because the CLI interface for the host won't survive update)
This resource contains a simple Proof of...
