Are my HDDs too cold?
Koala
I recently finished building and doing burin in for my system. I installed FreeNAS last night and everything is going well so far, have a jail running HDHomeRun DVR, all fine. Here is my system:
  • FreeNAS 9.10 Stable
  • Supermicro X10SL7
  • Intel Xeon 1231v3
  • 4*8GB Crucial CT102472BD160B
  • (6)WD30EFRX WD Red 3TB in RAIDZ2
  • 250 GB Samsung 850 Evo (Jails)
  • 16GB SATADOM-SV 3ME3 (boot)
  • EVGA 220-G2-0550-Y1
  • Lian Li v358b
My case has 2 fans right in front of the HDDs, in which I have some Delta AFC1212D-PWM 120mm fans that idle at 1500RPM. I'm starting to think these are overkill. My HDDs sit at 27-29C when not doing anything. I started copying large files around to see if I could create some load and they never moved above 29C. I heard that low temps were as bad for fans as high temps so I was wondering if I need to rethink my cooling strategy and go for something quieter but warmer?
SweetAndLow
Sweet'NASty
Yes drives can be to cold but you are probably fine. As long as you don't have crazy low temps then crazy high temps I think things are fine. Sometimes my drive's hit 19c which is probably too cold, lol.
