Greeting all, tonight is my first time setting up and using FreeNas, so far I like it. I am no where near what I would call fluent in linux. The most time I have spent was tinkering with a few Raspberry Pi projects. The question that has me feeling like a complete idiot is; is there something special I need to do to turn on apt-get commands? I keep getting a command not found. This is while attempting it with a standard user using sudo apt-get update AND while trying as root (i know its a no no). On the user Jay for example, during creation I enabled the allow sudo option but I still get the same result. Seems during the raspberry projects I had to change a file or a setting, but for the life of me I can't find, but in all honesty, I'm not sure I had to.
Can anyone suggest what I might be missing? Is there other information that I need to supply to troubleshoot this? I know it is probably something stupid...
Please advise and thank you in advance.
PS I did search prior to asking, I got 9 results which didn't seem to look remotely close to this issue.
Thanks again
Thanks again
