TrueNAS-SCALE-22.12.3.2
Xeon X5675
evga x58 classified MB
18 GiB ram
Hi, for a week I have been trying to figure this out with no luck. My apps all disappeared and in their place was this message:
A search told me that the message was from k3s failing to start.
k3s_daemon.log snippet:
I've tried a number of things from other posts including:
unset pool/restart/set pool
made sure my system clock is set properly
deleted the token file in ix-applications/k3s/server
Any advice would be appreciated, thank you.
Xeon X5675
18 GiB ram
@truenas[~]# systemctl start k3s
Job for k3s.service failed because the control process exited with error code.
See "systemctl status k3s.service" and "journalctl -xeu k3s.service" for details.
Jul 19 17:21:19 truenas k3s[11787]: W0719 17:21:19.611695 11787 reflector.go:424] storage/cacher.go:/apiextensions.k8s.io/customresourcedefinitions: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key
Jul 19 17:21:19 truenas k3s[11787]: E0719 17:21:19.611726 11787 cacher.go:440] cacher (*apiextensions.CustomResourceDefinition): unexpected ListAndWatch error: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key; reinitializing...
Jul 19 17:21:20 truenas k3s[11787]: W0719 17:21:20.662290 11787 reflector.go:424] storage/cacher.go:/apiextensions.k8s.io/customresourcedefinitions: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key
Jul 19 17:21:20 truenas k3s[11787]: E0719 17:21:20.662323 11787 cacher.go:440] cacher (*apiextensions.CustomResourceDefinition): unexpected ListAndWatch error: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key; reinitializing...
Jul 19 17:21:21 truenas k3s[11787]: W0719 17:21:21.701995 11787 reflector.go:424] storage/cacher.go:/apiextensions.k8s.io/customresourcedefinitions: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key
Jul 19 17:21:21 truenas k3s[11787]: E0719 17:21:21.702022 11787 cacher.go:440] cacher (*apiextensions.CustomResourceDefinition): unexpected ListAndWatch error: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key; reinitializing...
Jul 19 17:21:22 truenas k3s[11787]: W0719 17:21:22.778184 11787 reflector.go:424] storage/cacher.go:/apiextensions.k8s.io/customresourcedefinitions: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key
Jul 19 17:21:22 truenas k3s[11787]: E0719 17:21:22.778223 11787 cacher.go:440] cacher (*apiextensions.CustomResourceDefinition): unexpected ListAndWatch error: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key; reinitializing...
Jul 19 17:21:23 truenas k3s[11787]: time="2023-07-19T17:21:23-07:00" level=info msg="Tunnel server egress proxy waiting for runtime core to become available"
Jul 19 17:21:23 truenas k3s[11787]: W0719 17:21:23.828970 11787 reflector.go:424] storage/cacher.go:/apiextensions.k8s.io/customresourcedefinitions: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key
Jul 19 17:21:23 truenas k3s[11787]: E0719 17:21:23.828999 11787 cacher.go:440] cacher (*apiextensions.CustomResourceDefinition): unexpected ListAndWatch error: failed to list *apiextensions.CustomResourceDefinition: couldn't get version/kind; json parse error: invalid character ';' after object key; reinitializing...
Jul 19 17:21:23 truenas k3s[11787]: time="2023-07-19T17:21:23-07:00" level=info msg="Waiting to retrieve kube-proxy configuration; server is not ready: https://127.0.0.1:6443/v1-k3s/readyz: 500 Internal Server Error"
