Sean Hafeez
- Jun 23, 2014
1. rsyncd (current working solution) is removed in Cobia
2. want to rsync from local machine to SMB mounted share to replace #1
3. all systems clients are MacOS with files on APFS systems
4. TrueNAS shares are SMB with "Enable Apple SMB2/3 Protocol Extensions" checked.
5. mount SMB on Mac. run rsync which wants to delete / replace 1000+ files (same with or without utf-8-mac,utf-8 set)
6. okay, let it do it. run again to see if things are synced. wants to delete and replace same files again.
8. remove everything it wants to delete by hand (just in case it is having issue removing files).
9. run again, files copied up. run again to check. same issue.
Okay, so I did a scrub of the community post and there is not a working answer for this as far as I can tell. Setting fruit:encoding = native in SMB results in shares that can be seen in Finder but disappear when you try to mount them.
Here is an example of the file/folder names:
deleting Wolfgang Amadeus Mozart/Cosi Fan Tutte (Concerto Köln, René Jacobs)/
deleting Wolfgang Amadeus Mozart/Don Giovanni (Ghiaurov, Janowitz, Burrows, Zylis‐Gara, Evans, Herbert Von Karajan)/51 Don Giovanni - Atto Secondo - Ah Dove È Il Perfido.m4a
