It is. I don't know if rebasing FreeNAS on FreeBSD 11.2 is in the works for 11.2 official release. If it is from what testing I've done on previous versions you should have no issues upgrading the jails.
That seems like a pretty big change between -BETA and -RELEASE (though admittedly, with iX, those are somewhat arbitrary designations). I thought with 11.0 we were finally back to matching the underlying FreeBSD release?
And just for the record, I updated an 11.1-U6 system to 11.2-RC2. The iocage jails stayed at 11.1 and worked just fine. I tried upgrading one of the jails to 11.2 using the GUI jail management and that worked just fine as well.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
