Anyone running more than 24 Disks on LSI SAS9305
klu
Hey everyone,
since I cannot solve my problem over here, I was wondering if anyone is successfully running more than 24 Disks on an LSI SAS9305-16/24i/e
blanchet
I run 44 disks with
It runs out-of-the-box with TrueNAS Core 12.0u6.1 server.
klu
Thank you, so it could be a problem with my controller. I basically have 2/4 IOM6, but whatever I do, I can only see 24 disks in TureNAS Core. Interestingly I can see disks from both my disk shelves at the same time but never more than 24.
Just out of curiosity, what firmware do you run on your controller? I am running "16.00.12.00 - IT-Mode" and tried "16.00.11.00 - IT-Mode" but did not go further down, yet.
blanchet
On my LSI9300-8e, I use firmware 16.00.01.00.
The HBA was shipped with this version, and I have never upgraded yet because it works well until now.
klu
Today I just got more confused. I swaped my SAS9305-16i for a SAS9211-8i and suddenly I can see all 31 drives I got in my enclosures.
So it might be a problem of the firmware I got on my SAS9305-16i or the problem is very specific for the SAS9305-16i (sas3224).
So anyone here that got exactly a SAS9305-16i/e (sas3224) and running more than 24 disks?
Might you have some weird RAID firmware remnants left? In RAID mode, the number of disks is typically very limited, but that's not really a thing for IT/IR modes. Or at least it wasn't for Gen 2/Gen 3 stuff. Gen 3.5 may be different.
klu
Actually I am using
Adapter Selected is a Avago SAS: SAS3224(A1)
Controller Number : 0
Controller : SAS3224(A1)
PCI Address : 00:43:00:00
SAS Address : 500062b-2-02b5-e700
NVDATA Version (Default) : 10.00.00.05
NVDATA Version (Persistent) : 10.00.00.05
Firmware Product ID : 0x2228 (IT)
Firmware Version : 16.00.12.00
NVDATA Vendor : LSI
NVDATA Product ID : SAS9305-16i
BIOS Version : 08.37.02.00
UEFI BSD Version : 18.00.03.00
FCODE Version : N/A
Board Name : SAS9305-16i
Board Assembly : 03-25703-02003
Board Tracer Number : SP71503600
so no RAID-Mode. I did try to hook up 2 disk shelves as you can read here. After a while of testing I startet wondering, if it is possible to hook up more thant 24 disks at all. Espacially since the man page for mpr states
Broadcom Ltd./Avago Tech (LSI) SAS 3224 (24 Port SAS)
and I was not sure what the "24 Port" was refering to.
But I am going to try some older firmware in the next couple of days. I just can't get my head around why the "newer" and seemingly "better" SAS9305-16i controller is not working and the SAS9211-8i works right away.
blanchet
According to this post, SAS3 HBA may not work well with SAS2 expanders.
It would explain why the SAS9305-16i does not work with the Netapp DS4246, but the SAS9211-8i does.
klu
Thank you, like I said over in the other threa I will look into it. But the question for this one remains, since I cannot test it - due to a lack of SATA/SAS and power cables for more than 24 drives without disk shelve.
Has anyone a controller with a sas3224 chip (like SAS9305-16i or SAS9305-24i) running with more than 24 disks on TrueNAS/FeeBSD? It would ease my mind that It can be done and is not an issue between this specific chip and the mpr driver.
klu
So, another week and just more confusion. But I think it is just an incompatibility between FreeBSDs mpr driver and my setup.
I finally managed to hook up more than 24 drives to my SAS9305-16i. I attached 12 SATA drives directly and one Netapp DS4246. I could see all 12 SATA drives and 20 of the 24 drives from the shelve. So although it is not working like I want it to work, I can definitely hook up more than 24 drives to my SAS9305-16i.
So this seems to be figured out, I will continue other here because I got some new results on the problem.
