any way to reset to first installation
Robti
Hi is there anyway to reset everything back to factory or do i need to use the usb again ?
Thanks
System | General | Reset config (button at the bottom)
Depending on how much you intended to "reset"... all config will go, but data pools will remain with data on them, which can then be imported to a new install.
If you want to really clean the system out, you need to destroy the pools first (electing to wipe the data on that option screen)
Robti
Thanks I want to clear everything I upgraded from core to scale via a fresh install and played about with it then decided to add a drive so I destroyed the pool.
Thanks
Robti
Sorry should have said in scale
Thanks
