SOLVED Another can not ping problem and plugins are not loading
kingfree
Build FreeNAS-11.2-U5 Platform AMD Ryzen 5 2600 Six-Core Processor
16gigs Ram
RAID0 with 4 drives
64bit mobo
For the life I can not seem to ping any sites within the GUI shell. Im certain that my plugins are not being populated is becasue of this. I am certain that I have my IP's correct and other pertinent info correct.
this is what I have:
in my router settings -
ip (gateway) 192.168.254.254
DNS Server 1: 8.8.8.8/ dns.google
DNS Server 2: 8.8.4.4/ dns.google
subnet: 255.255.255.0
settings in freenas:
populated in the Dashboard
Nic - re0
ip address of my freenas: 192.168.254.1
Default Routes: 192.168.254.254
name servers: 127.0.0.1 <------------- is this my problem? if so, how do i correct?
populated under global config
ip4v default gateway: 192.168.254.254
name Server 1: 8.8.8.8
name Server 2: 8.8.4.4
under interfaces:
interface: re0
media staus: Active
DHCP no
IPv6: no
IPv4 address: 192.168.254.1/24
Where have i gone wrong??
ping in shell shows: can not resolve google.com host name look up failure
Redcoat
I cannot tell you what you may have done wrongly. I will tell you what works for me and what I have see work for many others,
Don't set static IP address in FreeNAS - set in your router by assigning the address you want to the MAC address of your FreeNAS NIC.
In Network, Global Config, put your Gateway address in all 4 spots for: ipv4 default gateway, name server 1, 2, 3 .
Leave your router as is.
I'm not sure why you have any entries under Interfaces.
kingfree
thanks for the help, RC.
I sat down at the console and decided to start from scratch. I simply reset the configuration file to default. I did this from the console setup screen after a reboot
As for some of my other settings that you mention, I think i might have read some wacky tutorials in my initial setup. arghhh!
anyway, my plugins now populate and I can now ping.
thanks again for some tips
cheers!
Redcoat
Glad you are up and running. Got to watch out for those those wacky tutorials!
melloa
Like that. You found the problem without help :)
Just kidding. Most likely was a network misconfiguration that you got right the second time. Me? I'm lazy ... I set the MAC address on my router and FreeNAS to DHCP. That way I have a LAN Static IP and no configuration's to make on the server.
