Hello
I want to build a small True NAS system for my home with the following ideals:
* Not too expensive, energy friendly
* Run True NAS with, for now, Emby and a few docker containers.
* AMD build (to avoid Intel ME)
* Small (I like the Fractal Node 304 Case)
* "recycle" some components I have (HDD + nvme)
After searching recommendations, posts ... (thanks a lot to the community and for the Hardware guide by the way !)
I ended up on the following build that seems to match my needs. I am just afraid that I may have missed something important to build a good NAS.
Build:
Case: Fractal Design Node 304 (-> mini ITX)
Motherboard: ASRock B550M-ITX/ac
CPU: AMD Ryzen r5 3600 (Should support ECC it seems not sure if all of them do or if I need to check something more specific)
RAM: 16G Kingston DDR4 2666 ECC
Power: CoolerMaster 450W GX450 (80PLUS)
Disks: 2* 4Tb WD Red HDD (I already have one)
System Disk: recycling a 256 GB nvme SSD I have
Does anybody see any mistake I could have made or issues with such a build or some places where I could save some money ?
PS: sorry I don't have vendors links, I am in china and only have JingDong Links which I guessed would be more a hindrance if I added them
PPS: I will try to put some feedback once done in case it could be useful for someone else having similar requirements.
PPPS: Happy new year of the Cow :)
Arvatarox
Build:
Arvatarox
