Bl4ckShadow
- Jan 28, 2016
Hey,
besides my NAS, I also want to build a second one for my brother who is also in need for network storage.
Now, we have planned only to use two drives (2x 4TB), as ~3,5TB are sufficient for him.
First of all: In terms of redundancy and data integrity, is it save to go with this in a RAID 1 configuration?
Especially as I've read many critical voices for example in terms of RAID5 - configs nowadays. Is the data save in case of a drive failure with consumer-grade hard-drives or do I need to worry and overthink the system?
The NAS will be used as a target for backups of 2-3 clients, as a music-, picture and (smaller) video-server etc., so your typical private household workload.
As of now, we've chosen the following components; I'd be looking forward if some experienced FreeNAS-guys looked over it and mentioned if there is anything wrong.
* HDDs: 2x WD40EFRX (4TB WD Red's)
* Mainboard with CPU: Asrock C2550D4I (Intel 4 core avoton)
* RAM: 8GB Kingston ValueRAM Single Rank DDR3-1600 regECC CL11 single module
* PSU: 450 watts Seasonic G-Series modular 80+ Gold (I struggle to find <400 watts PSUs with proper efficieny and cable-management...)
* Case: Lian-Li Q11B
What is the difference between ECC and (registered) regECC - RAM? What to choose?
In the future (~2 yrs), we would like to upgrade the NAS to a SSD-only based solution. As the board has only 2 Intel Sata-6 ports, two SSDs - also in RAID1 - are what we consider now. Is the CPU sufficient for this task? Especially with a 10Gbit/s - NIC and - environment.
I'd appreciate some words of you advanced builders out there. Thank you for any advice in advance! :)
Regards,
Patrick
Regards,
Patrick
