france1967
- Aug 27, 2014
Hello everyone
I'm here to ask for advice to you experts.
A friend of mine has a qnap, and after that I have spoken for a year of wonders of freenas and ZFS, he is convinced and asked me to make for him a plex server with the following characteristics:
- 4k transcoding capabilities
- small form factor, so ITX
- opportunity to expand disk capacity in the future
- but above all, and this must be the main feature, really silent
For now I thought about:
cpu: xeon e3 1230/1
ram: ecc crucial
case: fractal node 304
psu: seasonic fanless p-520
all noctua fans and heatsink
and so far it was easy :)
for the rest I had initially thought of a solution all ssd based.
Starting with 6x1tb ssd, consumer gear, sandisk ultra II or samsung 850 evo, to contain costs, and in the future have the possibility of double them using six 3.5" -> 2x 2.5" adapter, so I could fit in the node 304 up to 12 2.5" units.
but reading some old posts on the forum seem to have understood that ssd's in zfs have problems of reliability and/or duration.
Is it always a problem, or things have changed? (just wondering: raid6 vs raidz2 makes any difference for ssd's?)
Or do you think I can use some (min 6 max 12 units) 2.5" spinning disks? 1 tb wd red or 2 tb wd green? or else?
Any of you have experience with this type of discs? Are they silent?
As for the motherboard can you recommend a card that has at least 12 sata3 ports?
Thanks in advance!
cpu: xeon e3 1230/1
ram: ecc crucial
Thanks in advance!
