sunshine931
 - Jan 23, 2018
I've run FreeNAS on bare metal for years, but recently had need for more VMs with capabilities that exceed what I could do with bhyve or iocage jails.
I decided I'd migrate to ESXi on bare metal, with FreeNAS in a VM, and my HBA passed through to the VM.
I built things as I describe above - installed ESXi on bare metal, then created a FreeNAS VM and passed through my HBA, booted it up and noticed that my dmesg output is full of scary messages.
Any suggestions as what might be happening here?!
da0: <VMware Virtual disk 2.0> Fixed Direct Access SPC-4 SCSI device da0: 300.000MB/s transfers da0: Command Queueing enabled da0: 12288MB (25165824 512 byte sectors) da0: quirks=0x140<RETRY_BUSY,STRICT_UNMAP> da7 at mps0 bus 0 scbus33 target 44 lun 0 da7: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da7: Serial Number YVGG161D da7: 600.000MB/s transfers da7: Command Queueing enabled da7: 2861588MB (5860533168 512 byte sectors) da14 at mps0 bus 0 scbus33 target 51 lun 0 da14: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da14: Serial Number YVG08VSD da14: 600.000MB/s transfers da14: Command Queueing enabled da14: 2861588MB (5860533168 512 byte sectors) da1 at mps0 bus 0 scbus33 target 38 lun 0 da1: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da1: Serial Number YHKWT6TD da1: 600.000MB/s transfers da1: Command Queueing enabled da1: 2861588MB (5860533168 512 byte sectors) da16 at mps0 bus 0 scbus33 target 53 lun 0 da16: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da16: Serial Number YVGP6J9D da16: 600.000MB/s transfers da16: Command Queueing enabled da16: 2861588MB (5860533168 512 byte sectors) da4 at mps0 bus 0 scbus33 target 41 lun 0 da4: <HITACHI HUS72303CLAR3000 C442> Fixed Direct Access SPC-4 SCSI device da4: Serial Number YXG52N9K da4: 600.000MB/s transfers da4: Command Queueing enabled da4: 2861588MB (5860533168 512 byte sectors) da5 at mps0 bus 0 scbus33 target 42 lun 0 da5: <HITACHI HUS72303CLAR3000 C442> Fixed Direct Access SPC-4 SCSI device da5: Serial Number YXG5JE6K da5: 600.000MB/s transfers da5: Command Queueing enabled da5: 2861588MB (5860533168 512 byte sectors) da3 at mps0 bus 0 scbus33 target 40 lun 0 da3: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da3: Serial Number YVHT4K3K da3: 600.000MB/s transfers da3: Command Queueing enabled da3: 2861588MB (5860533168 512 byte sectors) da9 at mps0 bus 0 scbus33 target 46 lun 0 da9: <HITACHI HUS72303CLAR3000 C442> Fixed Direct Access SPC-4 SCSI device da9: Serial Number YXG554YK da9: 600.000MB/s transfers da9: Command Queueing enabled da9: 2861588MB (5860533168 512 byte sectors) da6 at mps0 bus 0 scbus33 target 43 lun 0 da6: <HITACHI HUS72303CLAR3000 C442> Fixed Direct Access SPC-4 SCSI device da6: Serial Number YXG5JEBK da6: 600.000MB/s transfers da6: Command Queueing enabled da6: 2861588MB (5860533168 512 byte sectors) da8 at mps0 bus 0 scbus33 target 45 lun 0 da8: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da8: Serial Number YVGHJUTD da8: 600.000MB/s transfers da8: Command Queueing enabled da8: 2861588MB (5860533168 512 byte sectors) da12 at mps0 bus 0 scbus33 target 49 lun 0 da12: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da12: Serial Number YHJUXDVG da12: 600.000MB/s transfers da12: Command Queueing enabled da12: 2861588MB (5860533168 512 byte sectors) da10 at mps0 bus 0 scbus33 target 47 lun 0 da10: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da10: Serial Number YHJEXGHD da10: 600.000MB/s transfers da10: Command Queueing enabled da10: 2861588MB (5860533168 512 byte sectors) da15 at mps0 bus 0 scbus33 target 52 lun 0 da15: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da15: Serial Number YHJVR0BG da15: 600.000MB/s transfers da15: Command Queueing enabled da15: 2861588MB (5860533168 512 byte sectors) da11 at mps0 bus 0 scbus33 target 48 lun 0 da11: <HITACHI HUS72303CLAR3000 C442> Fixed Direct Access SPC-4 SCSI device da11: Serial Number YXG5H3SK da11: 600.000MB/s transfers da11: Command Queueing enabled da11: 2861588MB (5860533168 512 byte sectors) da13 at mps0 bus 0 scbus33 target 50 lun 0 da13: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da13: Serial Number YVHJD88K da13: 600.000MB/s transfers da13: Command Queueing enabled da13: 2861588MB (5860533168 512 byte sectors) da2 at mps0 bus 0 scbus33 target 39 lun 0 da2: <HITACHI HUS72303CLAR3000 C1D6> Fixed Direct Access SPC-4 SCSI device da2: Serial Number YVGBAX8K da2: 600.000MB/s transfers da2: Command Queueing enabled da2: 2861588MB (5860533168 512 byte sectors) ses0: da12,pass13: SAS Device Slot Element: 1 Phys at Slot 0 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca01a9fdbcd ses0: da1,pass2: SAS Device Slot Element: 1 Phys at Slot 1 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca01adb9dc9 ses0: da2,pass3: SAS Device Slot Element: 1 Phys at Slot 2 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e14a42d ses0: da3,pass4: SAS Device Slot Element: 1 Phys at Slot 3 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e6445fd ses0: da4,pass5: SAS Device Slot Element: 1 Phys at Slot 8 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca046093f49 ses0: da5,pass6: SAS Device Slot Element: 1 Phys at Slot 9 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca0460a0e11 ses0: da6,pass7: SAS Device Slot Element: 1 Phys at Slot 10 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca0460a0e25 ses0: da7,pass8: SAS Device Slot Element: 1 Phys at Slot 11 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e1986b9 ses0: da8,pass9: SAS Device Slot Element: 1 Phys at Slot 12 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e1c4301 ses0: da9,pass10: SAS Device Slot Element: 1 Phys at Slot 13 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca0460964e5 ses0: da10,pass11: SAS Device Slot Element: 1 Phys at Slot 14 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca01a8a0ac9 ses0: da11,pass12: SAS Device Slot Element: 1 Phys at Slot 15 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca04609fa79 ses0: da13,pass14: SAS Device Slot Element: 1 Phys at Slot 20 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) GEOM: da1: the secondary GPT table is corrupt or invalid. ses0: phy 0: parent 500a098004347dbf addr 5000cca03e562df5 ses0: da14,pass15: SAS Device Slot Element: 1 Phys at Slot 21 GEOM: da1: using the primary only -- recovery suggested. ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e008515 ses0: da15,pass16: SAS Device Slot Element: 1 Phys at Slot 22 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca01aa14d25 ses0: da16,pass17: SAS Device Slot Element: 1 Phys at Slot 23 ses0: phy 0: SAS device type 1 id 0 ses0: phy 0: protocols: Initiator( None ) Target( SSP ) ses0: phy 0: parent 500a098004347dbf addr 5000cca03e269129 random: unblocking device. Trying to mount root from zfs:freenas-boot/ROOT/default []... GEOM: da2: the secondary GPT table is corrupt or invalid. GEOM: da2: using the primary only -- recovery suggested. GEOM: da3: the secondary GPT table is corrupt or invalid. GEOM: da3: using the primary only -- recovery suggested. GEOM: da4: the secondary GPT table is corrupt or invalid. GEOM: da4: using the primary only -- recovery suggested. GEOM: da5: the secondary GPT table is corrupt or invalid. GEOM: da5: using the primary only -- recovery suggested. GEOM: da6: the secondary GPT table is corrupt or invalid. GEOM: da6: using the primary only -- recovery suggested. GEOM: da7: the secondary GPT table is corrupt or invalid. GEOM: da7: using the primary only -- recovery suggested. GEOM: da8: the secondary GPT table is corrupt or invalid. GEOM: da8: using the primary only -- recovery suggested. GEOM: da9: the secondary GPT table is corrupt or invalid. GEOM: da9: using the primary only -- recovery suggested. GEOM: da10: the secondary GPT table is corrupt or invalid. GEOM: da10: using the primary only -- recovery suggested. GEOM: da11: the secondary GPT table is corrupt or invalid. GEOM: da11: using the primary only -- recovery suggested. GEOM: da12: the secondary GPT table is corrupt or invalid. GEOM: da12: using the primary only -- recovery suggested. GEOM: da13: the secondary GPT table is corrupt or invalid. GEOM: da13: using the primary only -- recovery suggested. GEOM: da14: the secondary GPT table is corrupt or invalid. GEOM: da14: using the primary only -- recovery suggested. GEOM: da15: the secondary GPT table is corrupt or invalid. GEOM: da15: using the primary only -- recovery suggested. GEOM: da16: the secondary GPT table is corrupt or invalid. GEOM: da16: using the primary only -- recovery suggested. vmx_init: processor does not support VMX operation module_register_init: MOD_LOAD (vmm, 0xffffffff82a1c470, 0) error 6 GEOM_MULTIPATH: disk16 created GEOM_MULTIPATH: da16 added to disk16 GEOM_MULTIPATH: da16 is now active path in disk16 GEOM_MULTIPATH: disk15 created GEOM_MULTIPATH: da15 added to disk15 GEOM_MULTIPATH: da15 is now active path in disk15 GEOM_MULTIPATH: disk14 created GEOM_MULTIPATH: da14 added to disk14 GEOM_MULTIPATH: da14 is now active path in disk14 GEOM_MULTIPATH: disk13 created GEOM_MULTIPATH: da13 added to disk13 GEOM_MULTIPATH: da13 is now active path in disk13 GEOM_MULTIPATH: disk12 created GEOM_MULTIPATH: da12 added to disk12 GEOM_MULTIPATH: da12 is now active path in disk12 GEOM_MULTIPATH: disk11 created GEOM_MULTIPATH: da11 added to disk11 GEOM_MULTIPATH: da11 is now active path in disk11 GEOM_MULTIPATH: disk10 created GEOM_MULTIPATH: da10 added to disk10 GEOM_MULTIPATH: da10 is now active path in disk10 GEOM_MULTIPATH: disk9 created GEOM_MULTIPATH: da9 added to disk9 GEOM_MULTIPATH: da9 is now active path in disk9 GEOM_MULTIPATH: disk8 created GEOM_MULTIPATH: da8 added to disk8 GEOM_MULTIPATH: da8 is now active path in disk8 GEOM_MULTIPATH: disk7 created GEOM_MULTIPATH: da7 added to disk7 GEOM_MULTIPATH: da7 is now active path in disk7 GEOM_MULTIPATH: disk6 created GEOM_MULTIPATH: da6 added to disk6 GEOM_MULTIPATH: da6 is now active path in disk6 GEOM_MULTIPATH: disk5 created GEOM_MULTIPATH: da5 added to disk5 GEOM_MULTIPATH: da5 is now active path in disk5 GEOM_MULTIPATH: disk4 created GEOM_MULTIPATH: da4 added to disk4 GEOM_MULTIPATH: da4 is now active path in disk4 GEOM_MULTIPATH: disk3 created GEOM_MULTIPATH: da3 added to disk3 GEOM_MULTIPATH: da3 is now active path in disk3 GEOM_MULTIPATH: disk2 created GEOM_MULTIPATH: da2 added to disk2 GEOM_MULTIPATH: da2 is now active path in disk2 GEOM_MULTIPATH: disk1 created GEOM_MULTIPATH: da1 added to disk1 GEOM_MULTIPATH: da1 is now active path in disk1 GEOM: multipath/disk16: corrupt or invalid GPT detected. GEOM: multipath/disk16: GPT rejected -- may not be recoverable. GEOM: multipath/disk15: corrupt or invalid GPT detected. GEOM: multipath/disk15: GPT rejected -- may not be recoverable. GEOM: multipath/disk14: corrupt or invalid GPT detected. GEOM: multipath/disk14: GPT rejected -- may not be recoverable. GEOM: multipath/disk13: corrupt or invalid GPT detected. GEOM: multipath/disk13: GPT rejected -- may not be recoverable. GEOM: multipath/disk12: corrupt or invalid GPT detected. GEOM: multipath/disk12: GPT rejected -- may not be recoverable. GEOM: multipath/disk11: corrupt or invalid GPT detected. GEOM: multipath/disk11: GPT rejected -- may not be recoverable. GEOM: multipath/disk10: corrupt or invalid GPT detected. GEOM: multipath/disk10: GPT rejected -- may not be recoverable. GEOM: multipath/disk9: corrupt or invalid GPT detected. GEOM: multipath/disk9: GPT rejected -- may not be recoverable. GEOM: multipath/disk8: corrupt or invalid GPT detected. GEOM: multipath/disk8: GPT rejected -- may not be recoverable. GEOM: multipath/disk7: corrupt or invalid GPT detected. GEOM: multipath/disk7: GPT rejected -- may not be recoverable. GEOM: multipath/disk6: corrupt or invalid GPT detected. GEOM: multipath/disk6: GPT rejected -- may not be recoverable. GEOM: multipath/disk5: corrupt or invalid GPT detected. GEOM: multipath/disk5: GPT rejected -- may not be recoverable. GEOM: multipath/disk4: corrupt or invalid GPT detected. GEOM: multipath/disk4: GPT rejected -- may not be recoverable. GEOM: multipath/disk3: corrupt or invalid GPT detected. GEOM: multipath/disk3: GPT rejected -- may not be recoverable. GEOM: multipath/disk2: corrupt or invalid GPT detected. GEOM: multipath/disk2: GPT rejected -- may not be recoverable. GEOM: multipath/disk1: corrupt or invalid GPT detected. GEOM: multipath/disk1: GPT rejected -- may not be recoverable.
