JoeFlorida
- Aug 14, 2016
I got an alert that ada0 had failed self check on 2018-01-09. ada0 is my boot disk.
I backed up my settings, I replaced it, re-installed and restored settings, all is good but I can't get the alert from 2018-01-09 to go away.
Normally if you have a degraded volume, the alert leaves when the volume no longer degraded.
the self check alert just stays and lingers on, it's not even for the current drive in ada0.
