I run commvault to backup items on my freenas box.
Been working mostly fine for a few years. By mostly, i mean its fine except I have a couple of steps I have to do after a reboot to get teh commvault service to run.
Other than that, it's been working fine.
Until TODAY
This morning, I upgraded to 11.1-U5 from 9.10-U6. Upgrade went fine and dandy, except I can no longer get the commvault service to talk with the commvault server.
The services are running just fine on freenas:
When trying to get teh server to talk to freenas, it fails saying communication is down.
The commvault client runs on ports 8400, 8401 and 8403
I have run sockstat -4 -l and as you can see below, it does appear to be listening.
Any ideas?
Until TODAY
root@G1PPFreeNas01:/etc # commvault status --------------------------------- Instance001 --------------------------------- [ General ] Version = 11(BUILD80) SP11 (1114128) CommServe = G1VPCMS01.firemountain.local Home Directory = /opt/commvault/Base Log Directory = /opt/log/commvault/Log_Files Core Directory = /opt/commvault Temp Directory = /opt/commvault/Base/Temp Platform Type = 4 Cvd Port Number = 8400 [ Package ] 1002/CVGxBase 11(BUILD80) = File System Core 1101/CVGxIDA = File System [ Physical Machine/Cluster Groups ] Display Name = 10.100.1.52 - Client Hostname = 10.100.1.52 - Job Results Directory = /opt/commvault2/iDataAgent/jobResults root@G1PPFreeNas01:/etc #
root@G1PPFreeNas01:/etc # sockstat -4 -l USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS root ClMgrS 68271 6 tcp4 *:44737 *:* root sshd 61838 4 tcp4 10.100.1.181:22 *:* root syslogd 60147 6 udp4 10.100.1.181:514 *:* nobody mdnsd 53623 4 udp4 *:58954 *:* nobody mdnsd 53623 6 udp4 *:5353 *:* nobody mdnsd 53623 7 udp4 *:5353 *:* nobody mdnsd 53623 8 udp4 *:5353 *:* root smbd 53570 34 tcp4 *:445 *:* root smbd 53570 35 tcp4 *:139 *:* root nmbd 53565 17 udp4 *:137 *:* root nmbd 53565 18 udp4 *:138 *:* root nmbd 53565 19 udp4 10.100.132.113:137 *:* root nmbd 53565 20 udp4 10.100.132.255:137 *:* root nmbd 53565 21 udp4 10.100.132.113:138 *:* root nmbd 53565 22 udp4 10.100.132.255:138 *:* root nmbd 53565 23 udp4 10.100.1.52:137 *:* root nmbd 53565 24 udp4 10.100.1.255:137 *:* root nmbd 53565 25 udp4 10.100.1.52:138 *:* root nmbd 53565 26 udp4 10.100.1.255:138 *:* root nmbd 53565 27 udp4 192.168.168.9:137 *:* root nmbd 53565 28 udp4 192.168.168.255:137 *:* root nmbd 53565 29 udp4 192.168.168.9:138 *:* root nmbd 53565 30 udp4 192.168.168.255:138 *:* root nmbd 53565 32 udp4 10.100.1.181:137 *:* root nmbd 53565 33 udp4 10.100.1.255:137 *:* root nmbd 53565 34 udp4 10.100.1.181:138 *:* root nmbd 53565 35 udp4 10.100.1.255:138 *:* root syslog-ng 53423 18 udp4 *:1031 *:* root hptsvr-htt 8767 3 tcp4 *:7402 *:* root uwsgi 7597 3 tcp4 127.0.0.1:9042 *:* root consul 7433 4 tcp4 127.0.0.1:8300 *:* root consul 7433 8 tcp4 127.0.0.1:8302 *:* root consul 7433 9 udp4 127.0.0.1:8302 *:* root consul 7433 11 tcp4 127.0.0.1:8301 *:* root consul 7433 12 udp4 127.0.0.1:8301 *:* root consul 7433 13 tcp4 127.0.0.1:8600 *:* root consul 7433 14 udp4 127.0.0.1:8600 *:* root consul 7433 15 tcp4 127.0.0.1:8500 *:* root consul-ale 7426 7 tcp4 127.0.0.1:8542 *:* root python3.6 7410 7 udp4 *:32272 *:* root uwsgi 7407 3 tcp4 127.0.0.1:9042 *:* www nginx 7341 6 tcp4 *:80 *:* root nginx 7340 6 tcp4 *:80 *:* root rsync 7144 5 tcp4 *:873 *:* root snmpd 5517 7 udp4 *:161 *:* root snmpd 5517 11 tcp4 *:199 *:* root sshd 5493 5 tcp4 *:22 *:* nobody proftpd 3283 0 tcp46 *:21 *:* root ntpd 3138 21 udp4 *:123 *:* root ntpd 3138 24 udp4 127.0.0.1:123 *:* root ntpd 3138 25 udp4 192.168.168.9:123 *:* root ntpd 3138 26 udp4 10.100.1.52:123 *:* root ntpd 3138 28 udp4 10.100.132.113:123 *:* root ntpd 3138 29 udp4 10.100.1.181:123 *:* root rpc.statd 3065 6 udp4 127.0.0.1:638 *:* root rpc.statd 3065 7 udp4 10.100.1.52:638 *:* root rpc.statd 3065 8 tcp4 127.0.0.1:638 *:* root rpc.statd 3065 9 tcp4 10.100.1.52:638 *:* root nfsd 3061 5 tcp4 10.100.1.52:2049 *:* root mountd 3055 7 udp4 127.0.0.1:738 *:* root mountd 3055 8 udp4 10.100.1.52:738 *:* root mountd 3055 9 tcp4 127.0.0.1:738 *:* root mountd 3055 10 tcp4 10.100.1.52:738 *:* root nfsuserd 3043 3 udp4 *:710 *:* root nfsuserd 3042 3 udp4 *:710 *:* root nfsuserd 3041 3 udp4 *:710 *:* root nfsuserd 3039 3 udp4 *:710 *:* root nfsuserd 3038 3 udp4 *:710 *:* root ctld 2809 6 tcp4 192.168.168.9:3260 *:* root rpcbind 2472 9 udp4 *:111 *:* root rpcbind 2472 10 udp4 *:808 *:* root rpcbind 2472 11 tcp4 *:111 *:* root python3.6 272 17 tcp4 *:6000 *:* ? ? ? ? udp4 10.100.1.52:2049 *:* ? ? ? ? udp4 *:* *:* ? ? ? ? udp4 *:765 *:* ? ? ? ? tcp4 *:601 *:* root@G1PPFreeNas01:/etc #
Any ideas?
