After update FreeNAS broke and server goes into a reboot loop.
Mihai Alex
Hello All,
I'm running FreeNas 9.3.1 Stable on HP Microserver Gen 8 everything worked fine for almost 1 month since I started using FreeNas , on Saturday i've noticed that some updates are available so I choose to install them .... and all hell brake loose...I couldn't get FreeNas to boot anymore ( see attached screenshot) , this is th error I got every time system boots up , I made a new installation on a USB drive , made the update and boom same issue but different errors...
anodos
Sambassador
Hello All,
I'm running FreeNas 9.3.1 Stable on HP Microserver Gen 6 everything worked fine for almost 1 month since I started using FreeNas , on Saturday i've noticed that some updates are available so I choose to install them .... and all hell brake loose...I couldn't get FreeNas to boot anymore ( see attached screenshot) , this is th error I got every time system boots up , I made a new installation on a USB drive , made the update and boom same issue but different errors...
Post full hardware specs.
Mihai Alex
Intel(R) Celeron(R) CPU G1610T @ 2.30GHz
Memory 6083MB
1 X WD RED 1TB HDD
FreeNas is installed on a 8GB USB Drive from SanDisk
MD656
Hopefully you find a solution to this. I have the same issue with the new update on different hardware. Debating making another post on it. Same exact error to the T. Attached image.
Mihai Alex
Alright so I've done the following:
Downloaded FreeNAS-9.3-STABLE-201511020249 and installed on a USB drive, the same issue occured . I used the same image and installed it on a diffrent USB drive and diffrent USB port and ....it works
The only two updated I have are the one below:
Upgrade: freenas-pkg-tools-9.3.1-STABLE-42a76e8 -> freenas-pkg-tools-9.3.1-STABLE-7afa903
Upgrade: docs-9.3.1-STABLE-42a76e8 -> docs-9.3.1-STABLE-7afa90
Update: Well I spoke to early ... after reboot it failed again. I'm done...
MD656
What type of USB drive were/are you using? Did you have it plugged into a USB3.0 port vs a 2.0 port?
MD656
This is my hardware. I tried doing the same thing as you (different USB drive, different port), and still having the same issue. Here is my setup:
USB Boot: SanDisk Cruzer Fit CZ33 16GB USB 2.0 Low-Profile Flash Drive- SDCZ33-016G-B35
Mobo/CPU: ASRock Intel Avoton C2750 2.4GHz/DDR3/SATA3/V&2GbE/Mini-ITX Motherboard and CPU Combo C2750D4I
Memory: 32GB DDR3/DDR3L-1600MT/s (PC3-12800) DR x8 ECC UDIMMs
Hard Drives: 6x3TB RAIDZ1, 2x120GB SSD l2arc/zil
@Mihai Alex, the bootloader should provide you with options of different boot environments. Can you just choose the previous one and boot that way?
Edit: Your system is definitely on the light side to run FreeNAS--the CPU is pretty weak, and 8 GB of RAM is the minimum. I don't know if either of those is affecting this issue, but they sure can't be helping.
Nucshuco
I Have the same problem on my FreeNas MINI. Crash when I get to ntpd. go back to FreeNAS-9.3-STABLE-201509282017 everything is fine. tried it on 3 different usb's same result. my SuperMicro works fine with the latest update.
https://bugs.freenas.org/issues/12135
