After replacing NIC, jail netstat returns "no namelist"
shawndewet
FreeNAS 9.3
HP Proliant Microserver.
16GB Ram
RaidZ Level: (don't know. How do I check this?)
The embedded NIC failed, and I have replaced this with a PCIe NIC. FreeNAS networking itself is working fine. I can remote in to the Web UI.
My root problem is that I am trying to get into my Crashplan headless server.
One of the steps is to check that the jail is listening on a certain port.
The check is done with netstat -na...
However, when I run this, I get "netstat: no namelist" as a response.
I'm thinking the epair virtual NIC for the jail might still be bridged to the old NIC? But I have no idea how to troubleshoot this (I'm a Windows guy, with limited Linux skills). Please help?
EDIT:
From within the jail, I can ping the default gateway, I can ping 8.8.8.8, but not www.google.com. (I can ping www.google.com from the FreeNAS host server)
DrKK
FreeNAS Generalissimo
when you're inside the jail, what do you get on "dig" and/or "drill", for example, do these resolve:
dig www.ibm.com
or
drill www.ibm.com
? Since you say you can ping 8.8.8.8 from the jail, then the routing/gateway looks good.
If the answer is no, then the problem is your DNS settings, and you should probably specify a nameserver (e.g., like 8.8.8.8) in the network global config.
Do your jails have "VIMAGE" checked? Are the jails on a fixed IP, or are their IP address obtained via DHCP?
shawndewet
Hi DrKK.
Jail has VIMAGE checked.
Jail is on a fixed IP.
I've attached screenshots of network global config, and of the jail setup.
Dig result is:
root@crashplan_1:/ # dig www.ibm.com
; <<>> DiG 9.8.4-P2 <<>> www.ibm.com
;; global options: +cmd
;; connection timed out; no servers could be reached
Drill result is:
drill: Command not found.
DrKK
and what happens with dig/drill?
shawndewet
Sorry I edited my reply to include dig/drill response.
DrKK
It seems you have no nameserver?
What are the contents of the file /etc/resolv.conf in this jail?
shawndewet
It was:
search local
nameserver 196.7.7.7
nameserver 196.7.8.9
Clearly this is the wrong DNS for my setup. So I edited the file to:
search local
nameserver 8.8.8.8
nameserver 8.8.4.4
Now I can dig www.ibm.com
However, my netstat command still returns "netstat: no namelist".
DrKK
shawndewet
I doubt it's related since the problem only started after I replaced the NIC.
