After I updated my system to 11.3
csearle
hey guys after I graded to 11.3 I get this error on my plugins and jails, can someone steer me in the right way??
  • plex: [EFAULT] Stopped plex due to VNET failure
  • transmission: [EFAULT] Stopped transmission due to VNET failure
hervon
Reported a few times in the forums. Searched ?
In my case I left the interface blank and vnet works fine. YMMV. Take a look at the other threads.
csearle
with transmission I took the NAT and reconfigured it
I have looked at other threads for Plex and still having issues
hervon
did you try the tip i gave you?
csearle
I did the auto ip ipv4 and left the interface blank and put in an ip dress for the IP address and no luck
I deleted the plugin and then restarted and then I went to reinstall Plex using NAT and this is the result
Plugin installed successfully
Install Notes:
plexmediaserver_enable: -> YES
plexmediaserver_support_path: -> /
Starting plexmediaserver.
Admin Portal:
I have Plex running now but I can't get my library to work..
You probably haven't yet set up the mount points to your library.
csearle
Solved I took notes from another post where one user entered NONE in the photo supplied. My DHCP started to work and my jails grabbed an IP address when I selected AUTO and all my jails are working perfectly..
