AFP Permission Issues | Can't Create Folders!
Juliano Arantes
Hello!
I've searched and read everything AFP related in the forum and couldn't find a solution to my problem...
Currently running FreeNAS-9.2.1.6-RELEASE-x64 (ddd1e39) on the following hardware:
Intel Pentium CPU G2020 @ 2.90GHz
Supermicro X9SCM-F
16GB RAM DDR3 1.333Mhz
2 x 1TB WD Red
I'm new to FreeNAS but had no problems installing and configuring everything but the AFP shares.
It works using CIFS, but as we only have Macs I don't want to use it and the speed wasn't good either!
My setup is actually pretty simple. I have one dataset called "plexmedia" where I'll store some pictures. I've created a user called "estudio" and made it part of a group called "onovodia". Than I've created an AFP share and set "Allow List: estudio" and "Read-write Access: estudio".
After that I can successfully login and transfer files to the share, deleting files is also not a problem. But for some unknown reason I can't create folders!
I've created the dataset choosing "Share type = Apple" and set the owner to "estudio" and the group to "onovodia". I've also chosen "Permission Type = Windows/Mac ACL". Checking folder permissions with getfacl returns:
# file: plexmedia
# owner: estudio
# group: onovodia
owner@:rwxpDdaARWcCos:fd----:allow
group@:rwxpDdaARWcCos:fd----:allow
everyone@:r-x---a-R-c---:fd----:allow
I've read on other threads I should not use the "Full Name" to login and that's also not the case...
Any help? I've been trying everything I could for three days...
Dennis.kulmosen
I am actually having the same issue. Even after upgrading from a 9.2.1.5 where everything works with making folders. After upgrading to 9.2.1.6 you cant create folders. I have looked in afp.conf but it has the correct folder permissions.
fracai
I've seen this occasionally and it's always been cleared up by restarting the AFP service.
Dennis.kulmosen
This happens after a completely fresh install and also after a GUI upgrade. I have tried restarting the AFP without luck.
fracai
I've seen that too, issues after z new install, and at least in my case the service restart fixed things.
Just relating my experience.
pleuroma
Having the same issue as above. Everything is configured for afp and worked great. Out of the blue I cannot write anything to the drives no matter how I configure permissions. Anyone had any luck resolving this?
Dennis.kulmosen
Follow the bug report. ;-)
Its been solved. As a quickfix you can in terminal do:
setfacl -b path/to/AFPshare
This will remove the ACL's on your share, and it will default to posix.
Yaniv
Can't believe it was that simple! Thank you so much! Worked for me.
Ben Wong
Just experienced this error where I could read/write files but not create directories. This is what I did. My NAS is on FreeNAS 9.3.
Let's assume my main share is: /mnt/datapool/main/media
  1. ssh into the NAS
  2. cd /mnt/datapool/main
  3. find media -type d -print0 | xargs -0 -n1 setfacl -b
Since setfacl isn't recursive, this will find all directories and sub-directories and fix the ACL on them.
Soypat
I fixed by doing the following:
1- Delete the AFP sharing.
2- Create a new AFP Sharing.
3- Set all the permission checkboxes on.
4- uncheck "AFP3 Unix Privs"
I beleive that the step 4 was the key one.
Good luck!
3agl3
Good luck!
I can confirm that just doing step 4 worked for me. Thanks.
calebmcd
1. Updated to the December 20, 2018 build
unchecked "AFP3 Unix Privs
This seemed to cause the issue for me.
