Simtech
- Feb 12, 2021
Good evening,
I have decided to move my data from storage solution to TrueNAS and initially decided on RaidZ2 but I'm concerned about re-silvering and availability. I currently have 4 x 14 TB drives and won't be in a position to buy any additional drives for a few months and it would be limited to 2 drives, unless one failed and I needed to rebuild the array. If I opted for Mirror could I later add another 2 drives to pool1 and increase the pool by another 14TB?
In the scenario below using mirrors how is data distributed in ZFS, if a single file was written to the array would it be stored on Drive 1 and a copy on drive 3. Once drive 1 was full it would then use drive 2 and mirror that across to drive 4? I suppose what I am asking is if a single drive was pulled could you read the data or would 2 drives be required as the data is split?
Pool 1
MIRROR
drive 1 p2
drive 2 p2
MIRROR
drive 3 p2
drive 4 p2
Thanks for your time
Simon
Pool 1
MIRROR
drive 1 p2
drive 2 p2
MIRROR
drive 3 p2
drive 4 p2
Simon
