So I have a post from the other day where I was looking to build my first real FreeNAS build with a Dell C2100.  Long story short, in my current house it's not a problem, but the house I'm moving to (temporarily while I build a house), the C2100 is too loud simply because my office is adjacent to the living room.  C2100 = no go.
So I'm looking at a new build; in a desktop form factor.
Chassis: U-NAS NSC-800
Motherboard/CPU: Supermicro A1SAI-2750F
RAM: Intelligent Memory 16GB DDR3L ECC SO-DIMM (1x16GB) - x4
HBA: LSI 9211-8i
PSU: SeaSonic SS-350M1U
PCIe Extension: 16X PCIe Extension Kit for NSC-800 Server Chassis
SATA DOM\M: Innodisk SATADOM-SV 3ME
Storage Drives: Toshiba 5TB PH3500U-1I72 - x8
SLOG Drive: Intel DC S3710 200GB
L2ARC Drive: Intel DC S3610 400GB
So my plan is to do this in two phases.
Phase 1:
Initial build, with 2 16GB DIMM's and all 8 storage drives (which I already own)
Phase 2:
Add 2 additional 16GB DIMM's, SLOG, and L2ARC drives.
The purpose of this NAS is primarily file storage. I plan to build a new hypervisor box when the Xeon-D stuff releases, and VM's will run with local SSD storage. Nightly backups of my VM's will be made, and stored on this FreeNAS box. All my services will be run in VM's on this other box (Plex, SB/CP/HP, UniFi Controller, Domain Controllers, Guacamole, Splunk, Observium, etc), so I do not need major processing power on the FreeNAS box, outside of what ZFS needs. Essentially, I want to make sure I can saturate a GbE link (and I will be using LACP between the 4 links on this C2750 motherboard).
I chose the 400GB Intel S3610 for L2ARC because of performance. The 200GB model has half the write speed, so I figured get the bigger drive and utilize HPA (Host Protected Area) to partition it down to ~200GB, which will effectively double the wear-out time.
I chose the 200GB Intel S3710 for SLOG as it appears to be the most performant drive I could find, while having a good period of durability.
I chose that U-NAS NSC-800 chassis because it's a desktop unit, and I believe it will have better airflow than the SIlverstone DS380.
Cost is definitely a concern, but I am building here for performance. I wish a mITX board existed with 8 DIMM's, but we all know that that's not likely. These 16GB DIMM's are definitely expensive (~$350/ea), but I'll buy them if it will increase performance.
My ultimate goal is optimal performance, and data reliability. I plan to do 4 vdev's of 2 drives mirrored. Effectively a RAID 10.
Questions:
1) Any alternative recommendations for a SATA DOM? Is there something better I can choose? I was looking at the 32GB model mainly because of the r/w speeds.
2) Any chassis recommendations over this NSC-800? Looking for something with hot-swap bays. Will be sitting on my desk so I don't want it to be too loud, but it doesn't have to be silent.
3) Any idea what kind of performance I can expect? Do you think I can saturate a GbE link at phase 1 (i.e., build with 32GB RAM and no SLOG/L2ARC)?
4) Any other recommendations/concerns/things to consider?
Thanks!
HBA: LSI 9211-8i
Phase 1:
Phase 2:
Questions:
Thanks!
