Hi, I'm looking to move to TrueNAS Scale with a ATX case and have picked out a few parts I would like some input on/alternatives to.
The machine will mainly be used as a torrent box, network share for media with Jellyfin/Plex, will use Docker for one basic app and possibly pihole, pfsense and openVPN.
Case: Antec P101:
Chose this because of easy to access 8 3.5" tool-less bays, but it is expensive at $149 AUD, if there are other recommendations I'm all ears.
CPU: Intel i3 12100E
The reason I'm looking at 12th gen is due to Alderlake bringing back ECC Ram support on some models (on 12100E but not 12100) + possibly needing Quicksync
I'm open to other suggestions, but I do want something decent that isn't incredibly power hungry/old with limited instructions
Motherboard: https://smicro.eu/supermicro-mbd-x13sae-f-b-1
This motherboard is on the W680 Chipset which is the only Alderlake platform with ECC support. It one 2.5gbit port and one 1gbit port as well as IPMI, which I don't know how often I will use but seems very useful compared to having to pull out a monitor and kb just to change some setting in the bios!
It has all the features I could dream of with 8 sata ports and 3 m.2 NVME ports but I can't find it for sale anywhere yet!
Asrock has two boards with 3 2.5gbit Ethernet, but no IPMI put me off: https://www.asrockind.com/IMB-X1314 & https://www.asrockind.com/IMB-X1712
Other questions:
As TrueNAS Scale doesn't have ZFS support, how important is ECC memory? If it's not needed, I can re-use my current 32GB DDR4 kit once I upgrade to DDR5 in a few months.
I have 6 drives ready to put in the system, I'm looking at running Raid 1 on 2x8tb, 2x 16tb and 2x18tb drives. Is this okay, or should I be looking at doing things differently? I'm happy with having one point of failure for the drives, but don't know much about how hard it is to add more redundancy later on with Raid 1 etc.
Case: Antec P101:
Other questions:
