Hmm, just check the latest 9.10 release and watchdog is now disabled by default so you should be fine. Log into the console and run
and make sure you don't see the watchdogd process running.
Back to your original question, also run
Make sure your MB Temperature and CPU Temperature are under 40C and you should be good.
ps auwx | grep watchdogd | grep -v grep
ipmitool sensor | grep Temp
