I currently have a single SSD that runs FreeNAS. I'd like to add a second SSD of equal size for redundancy. However, I'm reluctant without knowing for certain if the restore is generally considered reliable from others that have done it. Also, getting a second set of eyes to confirm my steps would be helpful.
I'm thinking these would be the steps, but please correct me if I'm wrong
1. Image the disk just in case...
2. Backup config (System\General\Save) running 11-U4
3. Open up and get the second SSD installed
4. Boot from a USB stick (same version)
5. This time select a mirrored installation and be sure if there is an option to wipe the primary storage, I don't do it...
6. Restore config.
Is this possible? Recommended?
6. Restore config.
