SOLVED Adding media to FreeNAS?
DLMJOSLIN
How do I get my media collection onto the drives in the server? I have tried copying them through the shares but I either get errors for permissions, I have to copy one file at a time, or my files can't be copied because they are "invisible"? Is there a more efficient method for doing this. I have close to 3 TB of media and copying them one file at a time isn't feasible. Please help.
Mirfster
pirateghost
Unintelligible Geek
A. Fix your permissions issue.
B. Copy files with a proper utility that will resume. Robocopy works well on Windows.
DLMJOSLIN
How are you trying to copy them? Are you using RoboCopy, command line, trying to Copy/Paste, etc?
I have been trying to copy them by drag and drop into the shared folder. I'm running Mac OSX 10.9.5
DLMJOSLIN
From that I know the permissions are all good to go. But then again I don't know too much. I have a Mac so most of the tutorials or threads dont talk about Mac, or they don't have too much info on FreeNAS 9.10
Mirfster
pirateghost
Unintelligible Geek
If permissions were good you wouldn't have trouble copying files....
DLMJOSLIN
The permissions error only happens when it comes to certain movie files, not the share itself. I'll upload a snapshot when i find it.
DLMJOSLIN
So instead of continuing to try this my way. What is the correct way to get media files/ files onto the NAS box?
pirateghost
Unintelligible Geek
You have several options.
Most people just use the CIFS shares and copy paste.
You could connect via NFS and copy paste
You could rsync
You could scp
You could sftp
You could FTP
There is no "correct way". Just the way that works for you.
It sounds like you have a configuration issue that you need to resolve
DLMJOSLIN
You could rsync
You could scp
You could sftp
You could FTP
probably so, I'll continue to troubleshoot. Thank you for your quick response time.
pirateghost
Unintelligible Geek
You haven't stated what files are "invisible", where your files currently are located, what filesystem is on that location, what client access you have tried, or what the actual permissions error is.
It would go a long way to helping if you provided better details than "I tried through shares and it doesn't work"
DLMJOSLIN
The files I want to copy are on a external HDD connected to my mac via usb 2.0, the NAS box is hard wired via Ethernet cable. The files that randomly say are invisible are not hidden, they too are on the external HDD. The files that show an error for permissions are on the same external HDD. I’, new to this so I’m unsure what you mean by “client access” and “file system”. I will attach screenshots with this post for visual aide. Since I’m running OSX I thought it was only logical to have an apple share, even though OSX supports CIFS shares.
The AFP share is set up as follows:
Path:/mnt/volume/Media
Share Comment:
Allow List:
Deny List:
Read-Only Access:
Read-Write Access:
Time Machine
Zero Device Numbers:
No Stat:
AFP3 Unix Privs: Selected
Default file permissions: Owner (Read, Write, Execute), Group (Read, Write, Execute), Other (read)
Default directory permissions: Owner (Read, Write, Execute), Group (Read, Write, Execute), Other (Read, Write, Execute).
As for the storage datasets themselves their permissions are set as follows:
Owner (user): Root
Owner (group): Wheel
Mode: Owner (Read, Write, Execute), Group (Read, Write, Execute), Other (Read, Write, Execute).
Permission type: Mac
Dataset Options:
Compressions Level: Inherit (lz4)
Share Type: Mac
Enable atime: Inherit (on)
Quota for this dataset: 0
Quota for this dataset and all children: 0
Reserved space for this dataset: 0
Reserved space for this dataset and all children: 0
ZFS Deduplication: Inherit (off)
pirateghost
Unintelligible Geek
I recommend using CIFS shares instead of AFP.
The error messages indicate that the permissions issue is on the external drive itself, not the NAS. From what I can tell at least.
By client access and protocol I meant how you were accessing the NAS, and how you were accessing the source data. You answered both of those unknowingly.
I would switch over to CIFS and try that instead. AFP is a POS
DLMJOSLIN
Definitely will do that and see if there is a change, I'll update afterward for any other Mac user having the same issue.
DLMJOSLIN
How is that HDD formatted? If it uses a filesystem that FreeNAS can read, it sounds like the easiest thing to do would be to use Import Disk from the web UI: http://doc.freenas.org/9.10/freenas_storage.html#import-disk
And concur with @pirateghost about using CIFS instead of AFP--Apple is going to CIFS for almost everything (except Time Machine, AFAIK) anyway, and *nix support for CIFS is much better.
HDD is Formatted as MS-DOS (FAT 32). As for importing the drive does it need to be connected to the NAS box via usb?
Connected to the NAS box, yes. I don't know that it has to be via USB, but if it's a USB drive that would seem like the obvious way to do it.
DLMJOSLIN
Quick update! The first and luckily the only change I had to make was creating a CIFS share, then drag and drop my media files. It's been cake ever since, I appreciate all of the feedback and guidance.
