Adding disks to a raid10
andrema2
Hi
I have a raid10 as 2x6tb, 2x2tb and 2x4tb. One disk of 2 TB is failing. I have bought 2 4tb disks. My idea is to replace the 2x2tb set by the new ones.
So far, I’m unable to find a way to do it thorough the GUI.
It’s just change the first disk that is failing for one of the 4tb and once it’s finished recovering I change the second one and expand the pool ?
Or it has to be done via CLI only ?
How can I accomplish it ?
I’m running 12 U1.
Thanks
SweetAndLow
Sweet'NASty
It's documented in the manual
Pierce
replace the failed disk first, wait for it to remirror, then replace the other one and it will automatically expand.
andrema2
Tks. I followed the instructions on the manual and it was perfect.
I should have look it before asking. Sorry for that
