As the title says, I am trying to add the disk and I get this error message;
How do I add this disk, or what's the best/safest way of using it, if I can't add it to the pool?
If it matters, it is a VM, running under Proxmox. The system is running from a disk image file, the storage disks are attached via PCIe passthrough to a Dell PERC H200 HBA card, in JBOD.
You are trying to add a virtual device of type 'stripe' in a pool that has a virtual device of type 'raidz
