Add Audio Emulator to Win 10 VM
PolkaBass
Is their a way to add an audio emulator to my Win 10 VM? Using bhyve. Found some info in message boards but nothing definitve Thanks
I can see that my Windows 10 VM uses "Remote Audio" over RDP, which produces sound out of my RDP client.
What are you trying to do with the audio?
PolkaBass
Thank you for your response. I manage an internet radio station and I would like to run some of the station programming from the Windows VM on my TrueNAS. I use SAM Broadcaster PRO that requires some sort of audio interface to function. Curently there are "No Output Devices Found" on the VM. I'm at a lost as to how to add one
HoneyBadger
actually does care
Administrator
Personal Anecdote Only: I have used VB-Audio's Virtual Audio Cable for the purpose of getting an emulated audio device to exist in Windows VMs for gaming purposes (with the actual game + audio streamed elsewhere over the network) but I can't say if it will speak for your use case, or endorse the software.
