add a module option using cli tool.
crashpb
what is the proper way to add a load option to modules in scale?
so I've been looking around but couldn't find a proper way to add a load option to a module (hpsa in my instance), ie via CLI; cause using standard Debian method (add arg in modprobe.d then regenerate initramfs) doesn't seem to work for me.
morganL
Captain Morgan
Administrator
So, I think you are looking to add a iSCSI driver for the HP Smart Array?
You might want to describe what you are doing and why.... it might be a developer-type question for the discord channel.
crashpb
there is a method to use some old hp smart array raid cards in hba mode however for the system to see drives in HBA mode kernel (hpsa driver) needs some patches . (more info here hpsahba )
I am compiling truenas scale with the said patches pre applied, how ever I need to load hpsa driver with an option for the changes to come to effect, typical debian method seems to not work properly.
basically I want equivalent of doing the below code done via cli :
echo "options hpsa hpsa_use_nvram_hba_flag=1" > /etc/modprobe.d/hpsa.co
update-initramfs -u
