 - Dec 21, 2012
I just spun up my Freenas server again after letting it sit powered off for quite some time. While it was off I stole one of the HDD out of it as I needed it for another project. That disk was only part of a UFS from what I remember. Now that I have powered Freenas back on and try to use the disk I removed, I cannot seem to create a new file system on it. It does not show up in the gui menu under volume manager as a drive and to this point I am at a loss.
Heres what I have done so far
Quick Wiped the disk from the Web GUI, which didnt seem to help. I then did a dd if=zero of=dev/ada0 bs=1G for a few minutes then rebooted. Following the reboot I still could not put a file system on the drive.
I see the following in /var/log/messages
Mar 23 19:49:03 freenas kernel: ada0: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
Mar 23 19:49:03 freenas kernel: ada0: 114473MB (234441648 512 byte sectors: 16H 63S/T 16383C)
Mar 23 19:49:03 freenas kernel: ada0: Previously was known as ad0
Gpart show
root@freenas] /dev# gpart show
=> 34 15974333 da0 GPT (7.6G)
34 1024 1 bios-boot (512k)
1058 6 - free - (3.0k)
1064 15973296 2 freebsd-zfs (7.6G)
15974360 7 - free - (3.5k)
gpart show /dev/ada0
gpart: No such geom: /dev/ada0.
Zpool status -v
pool: freenas-boot
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
Any ideas?
Gpart show
Zpool status -v
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
Any ideas?
