thagino
- Mar 24, 2021
I used TrueNAS-12.0–U2.1 to connect to Windows Server 2012 R2 ActiveDirectory.
The output from "wbinfo -u", "wbinfo -g", and "getent passwd" succeeded but does not appear in the ACL permissions list for the dataset.
An error has occurred in Task Manager and the "midclt call core.get_jobs | jq" output is:
How do I assign an ActiveDirectory ACL to a dataset?
{ "id": 203, "method": "activedirectory.fill_cache", "arguments": [], "logs_path": null, "logs_excerpt": null, "progress": { "percent": null, "description": null, "extra": null }, "result": null, "error": "'utf-8' codec can't decode byte 0x8a in position 2872: invalid start byte", "exception": "Traceback (most recent call last):\n File \"/usr/local/lib/python3.8/site-packages/middlewared/job.py\", line 367, in run\n await self.future\n File \"/usr/local/lib/python3.8/site-packages/middlewared/job.py\", line 405, in __run_body\n rv = await self.middleware.run_in_thread(self.method, *([self] + args))\n File \"/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py\", line 10, in run_in_thread\n return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))\n File \"/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py\", line 25, in run\n result = self.fn(*self.args, **self.kwargs)\n File \"/usr/local/lib/python3.8/site-packages/middlewared/plugins/activedirectory.py\", line 1354, in fill_cache\n for line in netlist.stdout.decode().splitlines():\nUnicodeDecodeError: 'utf-8' codec can't decode byte 0x8a in position 2872: invalid start byte\n", "exc_info": { "type": "UnicodeDecodeError", "extra": null }, "state": "FAILED", "time_started": { "$date": 1616637148158 }, "time_finished": { "$date": 1616637148384 } }
