I'm having an issue using active directory and smb shares. It seems like everything is properly configured as there are no errors from the TrueNAS UI and everything is showing up as healthy. After clicking on save for the active directory settings, the SMB shares work, and authentication works perfectly. I also know authentication is really authenticating because using an incorrect password gives an error. Then about 10-30 seconds later, authentication stops working and NT_STATUS_LOGIN_FAILURE shows up when trying to authenticate using the same credentials as before.
I've ran through all the troubleshooting steps in the documentation here https://www.truenas.com/docs/core/directoryservices/activedirectory/ and everything is coming back fine even after the authentication stops working. I can still see all the groups and users. Status shows healthy.
Running TrueNAS-12.0-U3 and did a fresh install and restored from backup. Same results occur.
Any thoughts on the issue here?
Thanks!
Thanks!
