Activating Plugins
Hi all! New here, so I'm not sure if this is the right place to post.
Basically my problem is that every time I try to activate a plug in, it says "some error occurred". Not sure if it'd a cause, but my jails are a mess. They've been moved around, deleted, drives with them unmounted then re mounted, deleted again, etc. You get the idea. I've got no clue how to sort them out.
Any help is much appreciated.
System:
AMD FX-8350
8GB RAM
3TB WD RED
60GB WD BLACK (tried to use this to store jails, was probably a terrible idea)
Sent from my LG-H918 using Tapatalk
nojohnny101
Why not just delete all your jails and start over.? Are they currently even working?
Some jails you can pull some files that contain information regarding your settings and database information (plex for example) so you really wouldn't have much impact on what you have already setup.
Yeah, I've tried deleting them. No luck. Would it make any sense to have them on the 60GB drive? My original intention with that was so that there would be a folder in the file system of my main drive called "jails".
Thanks for the help
nojohnny101
I'm on my mobile so my responses will be short.
No. Most people put jails on separate drives to speed them up (SSD), but putting them on a mechanical drive, separate from your main pool would add no advantage. In fact it would be a disadvantage because it would have no parity and thus no redundancy
No. Most people put jails on separate drives to speed them up (SSD), but putting them on a mechanical drive, separate from your main pool would add no advantage. In fact it would be a disadvantage because it would no parity and thus no redundancy
I've sorted out all my jails, deleted and re installed everything, even did a fresh install of freenas. Getting the same error message. Any ideas?
