Acrolock temp files
Solway
Hi
I'm getting endless acrolock########.tmp files generated from opening of PDFs.
And some cant be deleted afterwards.
Its causing all major issue on backup cron jobs.
Im using TrueNAS-13.0-U5.3 (core)
With the following SMB settings enabled:
Shadow Copies, Alternate Data Streams and SMB2/3 durable Handles.
I see there is a way to disable the protection mode in Adobe DC, but that's a security risk to our users.
anodos
Sambassador
Hi
Can you send me a system debug via private message.
GEOptic
We have the same issue. Somehow we managed to reduce Acrolock configuring Adobe Enhanced Security.
We created a GPO to disable those options.
amoore
All of the ones I found seem to be dated from before we upgraded to 13.0-U5.3. I have a support ticket open with support, but waiting on a a reply.
How did you go about removing the acrolock files from the TrueNAS?
GEOptic
Removing acrolocks only works thru the TrueNas shell for us. :wink:
Bill D
I think most of my acrolock files occur when I am combining files. I am trying to save the files on a local harddrive to avoid files being created on the server.
ragametal
In my setup, I solved the acrolock file creation problem by disabling Adobe Enhanced Security, just like @GEOptic suggested. That was at least a year ago and i have not seen a single acrolock file ever since.
