acpi_tz0: _crt value is absurd
Jose Luis
I have a message in console reporting
acpi_tz0: _crt value is absurd , ignored (256.0c)
What's this message?
Yatti420
What kind of hardware are you running? Can you post the full message log.. var/log/messages
What version of freenas?
rm-r
i ALWAYS get this on my test HP laptop - its likley ACPI isn't playing nice with freenas and reporting ABSURD cpu temps - just disable ACPI in the bootup sequence - it goes away
rm-r
when you boot freenas - look at the screen attached to the machine (if its headless attach a screen), there will be a boot menu after a few seconds with the freenas logo in ascii art - on the left there is a list of options - choose the one to disable it
rm-r
but also - it makes no difference - apart from the annoying message!
