ACL Permissions - No access for Owner
andyjay777
I am having some "issues" with ACL permissions on my SMB shares.
From Win11 PC, I use the login credentials for the user "andrew". OK to access SMB share.
Plex (Truecharts version) also uses the folder (user "apps"). Plex updates automatically when files are added.
I have a Win10 VM running in Scale. I use the login credentials for the user "Pirate". OK to access SMB share.
Problem: If the user Pirate creates a folder on the SMB share, the user "andrew" cannot access the same folder (even though that user is the owner). I then have to apply permissions recursively to get access.
