Sounds like you've had some kind of hardware failure. But, with the very little detail you have provided, your only option is to pull the rug from under it and hope for the best.
Suggest you post your hardware specifications (motherboard, CPU, RAM size/type, etc), what version of FreeNAS you're running and if possible, try to capture the error message.
