First of all, this problem has plagued many people. Through contact with APPLE, they think it is a problem of NAS manufacturers, and NAS manufacturers do not recognize that their SMB has problems. As a user, this makes him feel very sad.
After several days of testing, I found some problems in macos smblog. I don't know if my guess is correct. The following is my macos smblog.
I use FCPX to edit PRORES422 video in macos, SMB will exit unexpectedly when encountering multi-track video, FCPX will also become unresponsive, but the speed of copying files can reach 1GB/S (because I use 10GB Network), reading and writing files will not disconnect the SMB. I sincerely hope that someone can care about this issue.
I don't know if the SMB disconnection is related to it. This is what I found in APPL.
2021-01-30 00:16:51.294470+0800 0x5436 Default 0x0 0 0 kernel: (smbfs) smb_iod_rq_enqueue: SMB 1 not allowed on SMB 2/3 connection. cmd = 32
2021-01-30 00:16:51.297530+0800 0x5436 Default 0x0 0 0 kernel: (smbfs) smb_ntstatus_error_to_errno: Couldn't map ntstatus (0xc00000e5) to errno returning EIO
2021-01-30 00:16:54.839762+0800 0x5438 Default 0x0 0 0 kernel: (smbfs) process_svrmsg_items: disabling svrmsg notify, error: 9
2021-01-30 00:17:08.978452+0800 0x55d2 Default 0x0 0 0 kernel: (smbfs) smbfs_set_create_vap: smbfs_setattr, error 13
2021-01-30 00:17:09.000717+0800 0x55d2 Default 0x0 0 0 kernel: (smbfs) smbfs_set_create_vap: smbfs_setattr, error 13
2021-01-30 00:17:09.035936+0800 0x55d2 Default 0x0 0 0 kernel: (smbfs) smbfs_set_create_vap: smbfs_setattr, error 13
2021-01-30 00:17:09.212015+0800 0x55d2 Default 0x0 0 0 kernel: (smbfs) smbfs_set_create_vap: smbfs_setattr, error 13
2021-01-30 00:17:09.248349+0800 0x55d2 Default 0x0 0 0 kernel: (smbfs) smbfs_set_create_vap: smbfs_setattr, error 13
2021-01-30 00:17:43.345371+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) nbssn_recv: Breaking connection, sock_receivembuf blocked for 20
2021-01-30 00:17:43.345416+0800 0x5438 Default 0x0 0 0 kernel: (smbfs) smb2_smb_parse_change_notify: smb_rq_reply failed 60
2021-01-30 00:17:43.499167+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb2fs_reconnect: Missing durable handle .lock
2021-01-30 00:17:43.510489+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb2fs_reconnect: Missing durable handle .CurrentVersion.fcpevent-conch
2021-01-30 00:17:43.510664+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb2fs_reconnect: Missing durable handle .CurrentVersion.fcpevent-conch
2021-01-30 00:17:43.510833+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb2fs_reconnect: Missing durable handle .CurrentVersion.fcpevent-conch
2021-01-30 00:17:43.512046+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb2fs_reconnect: Missing durable handle .CurrentVersion.flexolibrary-conch
2021-01-30 00:17:43.513011+0800 0x5358 Default 0x0 0 0 kernel: (smbfs) smb_iod_reconnect: Failed to reconnect share ZFS0 with server 192.168.5.50
2021-01-30 00:17:43.513080+0800 0x56a6 Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 26af294b4ac92dcc
2021-01-30 00:17:43.513100+0800 0x591e Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513104+0800 0x58a5 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513104+0800 0x5615 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513106+0800 0x589c Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513106+0800 0x5658 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513109+0800 0x5622 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513110+0800 0x5659 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513111+0800 0x5916 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513113+0800 0x58a2 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513115+0800 0x58a4 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513119+0800 0x5918 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513120+0800 0x58c1 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513122+0800 0x5919 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513124+0800 0x58d6 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513124+0800 0x5751 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513158+0800 0x591c Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513178+0800 0x564f Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513180+0800 0x591b Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513182+0800 0x591a Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513188+0800 0x5917 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513193+0800 0x58c3 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513194+0800 0x58a3 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513208+0800 0x591d Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513211+0800 0x5601 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513232+0800 0x58d7 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513239+0800 0x55fe Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513240+0800 0x58c0 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513248+0800 0x58c4 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513253+0800 0x58e7 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513255+0800 0x5614 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513526+0800 0x58c2 Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513533+0800 0x574c Default 0x0 0 0 kernel: (smbfs) smb2_smb_read_write_async: smb_rq_reply failed 57
2021-01-30 00:17:43.513750+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 6dcf1a6d85860433
2021-01-30 00:17:43.513757+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid dca7599ba2d356a2
2021-01-30 00:17:43.513800+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 18a03fe759df88e9
2021-01-30 00:17:43.513806+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid b3570a29c6fed7c8
2021-01-30 00:17:43.513844+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 4dd386b4c07fe229
2021-01-30 00:17:43.513850+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid a496e0ceff20d65d
2021-01-30 00:17:43.513884+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 76c7c79c01174624
2021-01-30 00:17:43.513890+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid e03a01f1a24c25f0
2021-01-30 00:17:43.513925+0800 0x562b Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid 577fcda1da00be08
2021-01-30 00:17:43.514049+0800 0x56a6 Default 0x0 0 0 kernel: (smbfs) smbfs_lookup: Server failed Query Info 57
2021-01-30 00:17:43.518151+0800 0x5ad3 Default 0x0 0 0 kernel: (smbfs) smb_fid_get_kernel_fid: No SMB 2/3 fid found for fid ca6dfe819ad74cbf
