I have a TrueNAS-12.0-U1.1 System that I use with several services, that is working normal.
When I try to use TimeMachine from my Mac against a samba share with default settings as Multi-user Time Machine, recurrently got the messages pasted next.
Any sugestion on what is happening?
Regards,
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.471891+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.439457, 0] ../../lib/util/fault.c:79(fault_report)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472058+00:00 nas-bispeira.matarruanos.private smbd 79488 - - ===============================================================
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472117+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472080, 0] ../../lib/util/fault.c:80(fault_report)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472169+00:00 nas-bispeira.matarruanos.private smbd 79488 - - INTERNAL ERROR: Signal 10 in pid 79488 (4.12.9)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472215+00:00 nas-bispeira.matarruanos.private smbd 79488 - - If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472265+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472232, 0] ../../lib/util/fault.c:86(fault_report)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472311+00:00 nas-bispeira.matarruanos.private smbd 79488 - - ===============================================================
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472363+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472330, 0] ../../source3/lib/util.c:830(smb_panic_s3)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.472411+00:00 nas-bispeira.matarruanos.private smbd 79488 - - PANIC (pid 79488): internal error
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.475772+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.475686, 0] ../../lib/util/fault.c:265(log_stack_trace)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.475843+00:00 nas-bispeira.matarruanos.private smbd 79488 - - BACKTRACE: 6 stack frames:
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.475892+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #0 0x801952d17 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.475939+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #1 0x802ccfb86 <smb_panic_s3+0x56> at /usr/local/lib/samba4/libsmbconf.so.0
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.475988+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #2 0x801952b07 <smb_panic+0x17> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476035+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #3 0x801952eee <log_stack_trace+0x20e> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476082+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #4 0x801952ae9 <fault_setup+0x59> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476129+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #5 0x80fd48c20 <_pthread_sigmask+0x530> at /lib/libthr.so.3
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476310+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.476270, 0] ../../source3/lib/dumpcore.c:315(dump_core)
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476357+00:00 nas-bispeira.matarruanos.private smbd 79488 - - dumping core in /var/db/system/cores
Feb 2 17:50:18 <daemon.err> 192.168.2.69 1 2021-02-02T17:50:18.476385+00:00 nas-bispeira.matarruanos.private smbd 79488 - -
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.471891+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.439457, 0] ../../lib/util/fault.c:79(fault_report)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472058+00:00 nas-bispeira.matarruanos.private smbd 79488 - - ===============================================================
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472117+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472080, 0] ../../lib/util/fault.c:80(fault_report)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472169+00:00 nas-bispeira.matarruanos.private smbd 79488 - - INTERNAL ERROR: Signal 10 in pid 79488 (4.12.9)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472215+00:00 nas-bispeira.matarruanos.private smbd 79488 - - If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472265+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472232, 0] ../../lib/util/fault.c:86(fault_report)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472311+00:00 nas-bispeira.matarruanos.private smbd 79488 - - ===============================================================
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472363+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.472330, 0] ../../source3/lib/util.c:830(smb_panic_s3)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.472411+00:00 nas-bispeira.matarruanos.private smbd 79488 - - PANIC (pid 79488): internal error
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.475772+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.475686, 0] ../../lib/util/fault.c:265(log_stack_trace)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.475843+00:00 nas-bispeira.matarruanos.private smbd 79488 - - BACKTRACE: 6 stack frames:
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.475892+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #0 0x801952d17 <log_stack_trace+0x37> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.475939+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #1 0x802ccfb86 <smb_panic_s3+0x56> at /usr/local/lib/samba4/libsmbconf.so.0
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.475988+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #2 0x801952b07 <smb_panic+0x17> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476035+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #3 0x801952eee <log_stack_trace+0x20e> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476082+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #4 0x801952ae9 <fault_setup+0x59> at /usr/local/lib/samba4/libsamba-util.so.0
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476129+00:00 nas-bispeira.matarruanos.private smbd 79488 - - #5 0x80fd48c20 <_pthread_sigmask+0x530> at /lib/libthr.so.3
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476310+00:00 nas-bispeira.matarruanos.private smbd 79488 - - [2021/02/02 17:50:18.476270, 0] ../../source3/lib/dumpcore.c:315(dump_core)
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476357+00:00 nas-bispeira.matarruanos.private smbd 79488 - - dumping core in /var/db/system/cores
Feb 2 17:50:18 <console.info> 192.168.2.69 1 2021-02-02T17:50:18.476385+00:00 nas-bispeira.matarruanos.private smbd 79488 - -
Feb 2 17:50:18 <user.info> 192.168.2.69 kernel: pid 79488 (smbd), jid 0, uid 0: exited on signal 6
Regards,
