On the console screen
"The web interface could not be accessed.
Please check network configuration "
There is no list when Configure Network Interfaces is done
Only "Selecty an interface (q to quit)" is displayed
I can not take the method I taught
For some reason unknown to me the output of ifconfig provided by you only shows the loopback interface (lo) and nothing else.
Please try to make sure that the Intel GbE LAN interface is not disabled in the BIOS setup and does work at all, eventually using some other bootable medium.
After checking the base functionality make sure that there is no network cabling problem present.
BTW: The forum software supports drag and drop for image files (just checked).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
