About CIFS with authenticated users only
anodos
Sambassador
I can't give any advice without actually seeing how your shares are configured.
Enable ssh, download putty, connect to your server and type 'cat /usr/local/etc/smb4.conf'
Copy the entire contents of your smb4.conf file from the scrollback buffer and paste it in notepad. Save and attach to this thread. Do the same with 'testparm'.
As far as clearing cached credentials goes, check this technet article. If you are using Windows XP, then google "clear cached network credentials windows xp".
hellfire93_br
Files was attached, sorry for the delay.
  • smb4.conf.txt
  • testparm.txt
hellfire93_br
Hey anodos, if you have seeing the files, the settings are correct? What you see?
Another thing, some computers on my network can access shares inside without prompt for username/password on /mnt/Dados. o_O
The computers have Windows 7, WORKGROUP as default, both on Ethernet and Wireless.
