Tommy C. K. Lau
- Oct 22, 2012
Hi
I have encounter a strange problem when I install Freenas and build volume today and I was wondering whether anyone could help me?
Here is my hardware:
MB:Asus P8H77-I
Ram: 2x8GB Kingston DDR3
HDD: WD Red NAS 3TB x 6
Power: Seven Stream 250w 80 plus bronze
case with 2x9cm fan.
The strange thing occur when I build a ZFS raidz1 or raidz2 using all 6 HDDs, volume will be degraded (the status will become yellow and it say unknown status for the volume) few seconds after file/folder transfering.
However If I remove any 2 of the HDD and build a volume with raidz1 or raidz2, the file transfer process was fine.
Another thing I tried is created 2 volumes with raidz1 (3 disks each), the file transfer was fine if you transfer a file/folder to one volume at a time.
If you transfer files/folder to both volumes at the same time, the volume using HDD port 5 and 6 will be degraded.
If you press restart/reset button, hdd in port 5 and 6 will dissapper in bios, you will do a full shut down to see both HDDs again.
Would it be possible that I need to upgrade my power supply?
Sorry for my english as I am not a native english speaker.
Thanks
MB:Asus P8H77-I
Thanks
