SOLVED A folder in my dataset is missing! How do I bring it back?
Estropelic
This all started when I did a quick ftp session to transfer some files over to my other server. I connected ftp as root "I needed a quick way in" and copied the folder over. Now the folder it non-existent. I try to recreate the folder and it says it's in use by another program. I'm not sure how to make my folder reappear.
Can you see it from a terminal (ssh) on FreeNAS itself?
Or how about from the Shell tab in the GUI?
Can you see what's going on from zpool status -v?
Estropelic
root@freenas:~ # zpool status -v
pool: FREENASPOOL
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Sun Jul 12 11:00:59 2020
3.47T scanned at 654M/s, 2.05T issued at 387M/s, 4.15T total
349G resilvered, 49.31% done, 0 days 01:35:11 to go
NAME STATE READ WRITE CKSUM
FREENASPOOL DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
replacing-0 UNAVAIL 0 0 0
9747905202141488059 UNAVAIL 0 0 0 was /dev/gptid/eeab9691-fcb0-11e5-9196-d05099c08766
gptid/7e01026c-c450-11ea-aeb6-d05099c2fe9b ONLINE 0 0 0
gptid/ef920553-fcb0-11e5-9196-d05099c08766 ONLINE 0 0 0
gptid/f06f1e07-fcb0-11e5-9196-d05099c08766 ONLINE 0 0 0
gptid/f14c5849-fcb0-11e5-9196-d05099c08766 ONLINE 0 0 0
gptid/f233969d-fcb0-11e5-9196-d05099c08766 ONLINE 0 0 0
gptid/f3147bd4-fcb0-11e5-9196-d05099c08766 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:01:40 with 0 errors on Sun Jul 12 03:46:40 2020
