hi. Ive been tingering around with my new Freenas 9.3 box and i have a few areas im a little unsure about.
HW:
X10SLM-F in a
SC836E16-R500B chassi
AOX-S2308L controller (LSI)
E3-1220v3 cpu
32GB ECC RAM
16GB SATA DOM for OS
16xST6000NM0004 Enterprise Nearline SATA
Network interfaces:
1. The motherboard has a dual nic, why does freenas chose 2 different drivers?
igb0 1xx.yy.3.137/24
em0 1xx.yy.3.127/24
2. Under interfaces, i have 0 entries, but both have gotten a dhcp address.
Where can i change my 2 default NICs, set static address, netmask etc?
If i add a nic, i just get a new nic/ip with the same mac-address
Storage:
1. I got 16 disk divived into 2 vdevs -> Volume at around 86TB.
It automatically made a dataset of the whole space and a new subdir called jail. Where did the jail come from? I see it also as a /v1/v1/jails directory which is empty
2. Under jails i have no entries... but i still got the jail directory??
Sharing:
1. Ive got some samba experience from RHEL over the years so i assumed cifs sharing would be easy, and the first share came up straight, no problem.
2. Made a user STORAGE, group and password. Used the default dataset and it made a storage directory, added it to windows, np!!
3. Doing this again with a new user, group, password, no way in hell it will work. Everything looks the same, but no way i can add it to windows, wrong password/user etc.. i even went in to the console and chowned the directory to the new user test.. no avail..
All in all, freenas works great and the performance is awesome on this hw!!
br Thor
HW:
X10SLM-F in a
E3-1220v3 cpu
32GB ECC RAM
Network interfaces:
em0 1xx.yy.3.127/24
Storage:
Sharing:
br Thor
