970 Evo Plus Error Logs - Need Help Reading These
Fleshmauler
Hello Folks,
Got some error logs for a Samsung 970evo Plus - Smart Tests all pass, but getting the following errors. (Full system details in Signature if needed).
To me, these errors seem like a non-issue, but I went ahead, updated firmware just in case. So far drive seems to be working fine, but want to get a 2nd opinion since I know just about jack on reading these. If anyone with more ability or experience could confirm if this is an issue or not, it would be appreciated.
@truenas[~]# smartctl -a /dev/nvme0n1
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Model Number:                       Samsung SSD 970 EVO Plus 250GB
Serial Number:                      S59BNM0R505950E
Firmware Version:                   2B2QEXM7
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 250,059,350,016 [250 GB]
Unallocated NVM Capacity:           0
Controller ID:                      4
NVMe Version:                       1.3
Number of Namespaces:               1
Namespace 1 Size/Capacity:          250,059,350,016 [250 GB]
Namespace 1 Utilization:            153,150,431,232 [153 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            002538 5511907441
Local Time is:                      Mon Feb 27 17:14:09 2023 EST
Firmware Updates (0x16):            3 Slots, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x005f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x03):         S/H_per_NS Cmd_Eff_Lg
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     85 Celsius
Critical Comp. Temp. Threshold:     85 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     7.80W       -        -    0  0  0  0        0       0
 1 +     6.00W       -        -    1  1  1  1        0       0
 2 +     3.40W       -        -    2  2  2  2        0       0
 3 -   0.0700W       -        -    3  3  3  3      210    1200
 4 -   0.0100W       -        -    4  4  4  4     2000    8000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        32 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    697,739 [357 GB]
Data Units Written:                 6,845,934 [3.50 TB]
Host Read Commands:                 8,479,198
Host Write Commands:                311,178,453
Controller Busy Time:               182
Power Cycles:                       75
Power On Hours:                     1,699
Unsafe Shutdowns:                   30
Media and Data Integrity Errors:    0
Error Information Log Entries:      61
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               32 Celsius
Temperature Sensor 2:               32 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0         61     0  0x1008  0x4004      -            0     0     -
Errors:
@truenas[~]# nvme error-log /dev/nvme0n1
Error Log Entries for device:nvme0n1 entries:64
 Entry[ 0]
error_count     : 61
sqid            : 0
cmdid           : 0x1008
status_field    : 0x4004(INVALID_FIELD: A reserved coded value or an unsupported value in a defined field)
parm_err_loc    : 0xffff
lba             : 0
nsid            : 0
vs              : 0
trtype          : The transport type is not indicated or the error is not transport related.
cs              : 0
trtype_spec_info: 0
 Entry[ 1]
error_count     : 0
sqid            : 0
cmdid           : 0
status_field    : 0(SUCCESS: The command completed successfully)
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 2]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 3]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 4]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 5]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 6]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 7]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 8]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[ 9]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[10]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[11]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[12]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[13]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[14]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[15]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[16]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[17]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[18]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[19]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[20]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[21]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[22]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[23]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[24]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[25]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[26]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[27]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[28]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[29]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[30]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[31]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[32]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[33]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[34]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[35]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[36]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[37]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[38]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[39]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[40]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[41]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[42]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[43]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[44]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[45]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[46]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[47]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[48]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[49]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[50]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[51]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[52]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[53]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[54]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[55]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[56]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[57]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[58]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[59]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[60]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[61]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[62]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
 Entry[63]
error_count     : 0
sqid            : 0
cmdid           : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
cs              : 0
trtype_spec_info: 0
You might want to read some of the posts on STH. Seems some of the Sammy M.2 SSDs might have a known firmware issue/defect. You might get responses from others who are actively encountering similar issues.
Fleshmauler
Yeah just plucked out & updated firmware on my Samsung drives once I saw those errors - stupid bootable .iso from Samsung's website apparently couldn't detect keyboard input - even virtual keyboard from my ipmi. SO MUCH FUN TAKING OUT SSDS & TRANSPLANTING THEM BETWEEN BUILDS!
Anyway, firmware is now up to date, but wondering if I'm correct & these are nonsense errors or not.
FWIW, I see similar errors on my Crucial P3+. https://www.amazon.com/dp/B0B25NTRGD
root@mele-ud22:/dev# smartctl -a /dev/nvme0
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-43-generic] (local build)
Model Number:                       CT500P3PSSD8
Serial Number:                      2242E67B5C2D
Firmware Version:                   P9CR40A
PCI Vendor/Subsystem ID:            0xc0a9
IEEE OUI Identifier:                0x00a075
Controller ID:                      1
NVMe Version:                       1.4
Namespace 1 Size/Capacity:          500,107,862,016 [500 GB]
Namespace 1 IEEE EUI-64:            6479a7 6d20000069
Local Time is:                      Mon Feb 27 17:28:35 2023 EST
Firmware Updates (0x12):            1 Slot, no Reset required
Optional NVM Commands (0x005e):     Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x06):         Cmd_Eff_Lg Ext_Get_Lg
Maximum Data Transfer Size:         64 Pages
Critical Comp. Temp. Threshold:     95 Celsius
 0 +     6.00W  0.0000W       -    0  0  0  0        0       0
 1 +     3.00W  0.0000W       -    0  0  0  0        0       0
 2 +     1.50W  0.0000W       -    0  0  0  0        0       0
 3 -   0.0250W  0.0000W       -    3  3  3  3     5000    1900
 4 -   0.0030W       -        -    4  4  4  4    13000  100000
 0 +     512       0         1
 1 -    4096       0         0
Temperature:                        42 Celsius
Available Spare Threshold:          5%
Percentage Used:                    0%
Data Units Read:                    57,565 [29.4 GB]
Data Units Written:                 720,825 [369 GB]
Host Read Commands:                 685,518
Host Write Commands:                33,763,004
Controller Busy Time:               33
Power Cycles:                       4
Power On Hours:                     403
Unsafe Shutdowns:                   0
Error Information Log Entries:      118
Temperature Sensor 1:               42 Celsius
Temperature Sensor 2:               48 Celsius
Temperature Sensor 8:               42 Celsius
Error Information (NVMe Log 0x01, 16 of 16 entries)
  0        118     0  0x100e  0x4005  0x028            0     0     -
root@mele-ud22:/dev# nvme error-log /dev/nvme0
Error Log Entries for device:nvme0 entries:16
 Entry[ 0]
error_count    : 118
sqid        : 0
cmdid        : 0x100e
status_field    : 0x2002(INVALID_FIELD: A reserved coded value or an unsupported value in a defined field)
phase_tag    : 0x1
parm_err_loc    : 0x28
lba        : 0
nsid        : 0
vs        : 0
cs        : 0
trtype_spec_info: 0
DaSnipe
Interesting I should check mine, getting these similar errors in my 970 Evo Plus 1tb drives
