9.3 upgrade not joy
n7qpp
Some background information I have been running 9.2.x from some time on this hardware with no issues. Have done many in place firmware updates/upgrade again with no problems.
Hardware is:
GIGABYTE GA-MA790XT-UD4P
Latest BIOS installed
On-board fire wire disabled
On-board audio disabled
8 GB of RAM 4x2GB​
I first tried to perform an in-place firmware upgrade but it failed. I suspect this was due to only having a 2GB boot flash drive. But I did not review any logs to confirm. Okay onto plan “B”. Here I was going to use the fresh install approach with 2 USB flash drives.
  1. Backed up the current system configuration – no problems
  2. Burn the ISO image to the flash drive (USB A) using the program suggested in the docs – no issues
  3. Insert USB A into the my FreeNAS box and boot into the installer – no issues
  4. Insert USB B (8 GB Drive) into my FreeNAS box the system sees the drive and the installer loads the 9.3 OS and completes with no errors.
  5. Shut down box and remove USB A drive
  6. Power up the system and it hangs on the BIOS screen right after it shows the CPU type but before the memory count.
  7. Okay so I try all the combinations of 4GB, 8GB, AND 16GB brand and non-brand USB drives for both USA A and USB B. They all work fine as USB A but all hang the same when used as USB B. I also tried moving USB B to all the different USB ports on the box made no difference. And just for kicks I even tried using a USB hard drive the results were the same.
  8. I did search the group and tried to read as much as I could for similar problems. One suggestion was to wipe the USB B drive which I did but the results are the same.
Any other suggestions or help
Thanks N7QPP
n7qpp
Forgot to add went back to the old 2GB boot flash drive the old system is up and running fine
avalon60
I had a problem with some USB drives I had, and finished up with using a 8GB Sandisk Cruzer Facet. The Corsair and Patriot USB drives I had would not boot up successfully.
Hope you get it sorted.
n7qpp
A disk is a separate physical hard drive. This will show you how to convert a MBR (Master Boot Record) disk to a GPT (GUID - Globally Unique Identifer) disk in Windows Disk Manager or in a command prompt. By default Windows uses MBR disks.
While all Windows can boot from a MBR disk, you can only boot from a GPT disk if your motherboard has an enabled UEFI BIOS and you have an operating system (Windows 7 or Windows 8) that supports booting to GPT that is installed with UEFI.
You can still have a separate GPT disk as a data disk if your operating system (see below) supports reading a GPT disk, even if your system disk that Windows is installed on is still a MBR disk.
Differences Between MBR and GPT Disks:
  • MBR disks are supported (readable) by all Windows operating systems.
    • GPT disks are only supported (readable) by Windows server 2003 SP1 +, XP 64-bit, Vista, Windows 7, Windows Server 2008, Windows 8, and above.
  • MBR disks use the standard BIOS partition table.
    • GPT disks use UEFI.
  • MBR disks supports up to 2TB per single partition.
    • GPT disks supports up to 256TB per single partition in Windows.
  • MBR disks supports up to 4 Primary partitions or 3 Primary partitions and 1 Extended partition with up to 128 logical volumes in the extended partition.
    • GPT disks supports up to 128 Primary partitions.
  • Removable disks are MBR disks by default.
    • Removable disks cannot be converted into a GPT disk.
So when the bootable USB drive is created by the installer what type is it MBR or GPT??
FreeNAS 9.3 uses GPT formatting for the boot USB. Gigabyte's product info page doesn't mention anything about a UEFI BIOS for that board, which is one strike. It's not designed as a server board, which is a second strike. It's an AMD board, which is a third strike. I can't say whether this board will or won't work with 9.3, but there are some definite red flags.
I can't say I'm surprised that it's not working for the reasons danb35 has listed.
